Tony Mont
- Apr 15, 2018
Hello everybody!
As the title says, I decided to do another WIP thread! Personally I'm a big fan of those because it gives me the chance to get feedback on my work as I go along. Also, this WIP is going to be on going since the knife is not completed like my last few WIPs.
The main focus of this build is fit and finish. For this reason, I've kept the design simple.
As you can see, nothing crazy going on, 7.5" blade with a hidden tang constructiion. The only "fancy" stuff going on is the shape of the guard. More likely I will change the shape of the handle once the time comes, this one looks way too simple.
With the design at hand and my fuel ready to go, I transfer the design to a piece of cooking paper and then onto the steel. This allows me to keep my paper design for later reference.
With my trusty angle grinder, I cut off anything that it is not a knife. I would love to forge this piece out but my current workshop does not allow for heavy forging. If everything goes as planned, in ~2 months I will have a new space and forge as I please!
With the profile out of the way, I flatten the ricasso. This always takes some back and forth to ensure a flat and parallel ricasso. This might be one of the most important steps of the build, the whole knife is referenced of the ricasso area. With that out of the way, I scribe and grind my center line.
With a fresh 60 grit belt I do my pre heat treatment grind.
I drilled and chamfered my future pin hole. The hole will not stay this big, it's just a step to make my life easier down the line.
Since I'm using c130, I will go for a hamon. I love doing them even though I still have a lot to learn about them.
The blade is clayed up and ready for thermal cycling and then quenching.
This is a far as I have gone. I'm going to do the heat treatment today and hope for the best on the hamon.
All comments and feedback are welcome!
To be continued soon!
