- Oct 21, 2009
Ok time to move forward, sorry in advance for the large pics but photobucket is killing me. Ok so last night we left off at the rose carving, I like the Idea that Steve and Karda had so im gonna go with that, but first lets move on the sheath more. For this one Im doing a reverse belt loop, instead of rolling the leather backwards for the loop you roll it forward into the sheath. This allows you to have the smooth side of the leather on both sides.
Before we glue it down, we have to cut our retention strap holes in the belt loop. I dont have any fancy tool to do it so I use my punch and exacto. I punch the holes at the top and bottom of the strap holes and then with my ruler and knife I cut to each hole
Once this is done I can now prep the loop for gluing. I use contact cement to glue up my sheaths, it works very well for me. Now with the retention strap holes done here is what it looks like prior to gluing up.
I will apply a few coats of cement to the area im gluing up, wait a few to set then put it together, pound it a few time with a rubber mallet to get any air bubbles out and then I clamp it up to let set more.
While that is setting up, lets move to some carving, the original pic i had was to large to fit the sheath so I had to retrace it out a tad smaller. I use a plastic transfer paper for leather to trace. I trace out the pic I need, check the size to the sheath and if good start the set up for carving. Here are a few pics of the set up
This is the rose I will be using, I traced it to size and ready to transfer to the leather,
Check the fit again,
To begin the transfer you have to case or wet the leather alittle, then put the pic on and begin to transfer it using a stylus, while doing this you lift the trace to see if your lines are good,
Then begin tracing,
Here is a quick pic of the tools I am using to do this carving.
I will explain more later got to run for a bit. enjoy
Then begin tracing,
