- Nov 20, 2008
I've gone and done it... started building a grinder, I'll take lots of pics and document as best I can to give ideas to others that want to make a cheap grinder.
Is it wrong that my workbench is a toilet?
A square wheel?
The contact and Idler wheels are made of 3/4" plywood, 3 layers each. This contact wheel was cut to 15" and will probably be 14.75" when trued up.
I use a piece of wire, screw and pen to draw the circles and then rough cut with a jig saw.
A good build deserves a few frosty beverages.
Contact wheel glued up.
Some more components; pillow blocks and steady bearings.
Idler wheel glued up, this one is 6" diameter.
So far, half a sheet of plywood, the 7/8" shaft, pillow blocks and steady bearings cost $75.00 Canadian.
I'm going to take the wheels and shaft to my machinist friend to drill the centre holes in them and to cut a 1/8" shoulder 2" in on the left side of the shaft and so I'll have a 2" section of 5/8" shaft which will be reverse threaded so that I can put polishing/buffing wheels on the left side of the shaft.
A square wheel?
