WIP...Making A socket Spearhead
Up at 4am, coffee, eggs, out the door be 5am. 28 degrees, frost, beautiful day to forge! I'm excited, because today I'm starting to forge my first socket spearhead.
I've been a member here a long time, this is my first work in progress. Since I've never made a socket spear, I thought we could share the adventure. I may screw it up, I may not, but I'll be happy to include you guys in this effort.
This won't be a fast WIP, because I have a lot going on right now. But I will religiously update it as I make progress.
First, I guess you guys know that spears, just like knives and swords, can be stunningly beautiful. Here's a couple of examples I particulary like. More soon.
I'll be watching this...
I've made a few spears with an open wrapped socket, but my one attempt at a solid socket did not go so well.
I would normally start with round stock and forge it out, easier to get the right shape. However, I'm going to use what I have on hand. I'll use a 5/16's thick, 14" long, 3" wide piece of W2. My first step is to plan out what I want to accomplish, in this case a willow leaf socketed spear. Since I've never done this, I spent a good amount ot time doing research on the internet, and then drew an actual size cutout.. I decided to do the spear in two pieces. Hopefully, I'll be able to successfully forge wield the two together. Later today, if I get the chance, I'll post more as I start forging.
And mine might not either, but I am going into this with a method that's worked for others. My main concern at the moment is I think I would have been better off if I'd used round stock, easier to get a good transition between the two pieces.
I can tell you what didn't work... I forged the blade out of mild steel with a 1095 edge wrap, and a round 'tang' about 1" long and 1/2" diameter. The socket was made from 1" thick-walled iron pipe, forged to a taper that fit the tang perfectly. My attempt to fireweld the tang to the pipe did not go well, I could not get it to stick and the more I tried the worse it got. I've since been told that iron pipe doesn't like to fireweld, so when I attempt it again I will use the same mild for the socket that I use for the body of the blade... wrap it around a mandrel, fireweld the seam, and then fireweld it to the tang. This seems to be one of the methods used to make the originals. I'd like to eventually make a nice patternwelded spear, but need to work out the process with less expensive materials first...
I don''t know which way I'll go. I did think of using black pipe, putting a couple of 1/4" pins through the pipe and tang, and then using my welder. I think I could get a seamless joint that way. I'm also thinking of simply making the socket as you describe, but I'm not confident I can successfully firewweld the seam so it doesn't show.
After a few hours of forging and grinding, the spearhead is about done. I didn't take a lot of pictures of this process, I was too danged busy. But, here's a few pictures showing some forging using my charcoal forge, and where I'm heading with the spear. When I post again, I'll tackle the hardest part of this process, welding the spearhead and socket together.
