A friend of mine requested a 1/4" english mortise chisel. Mortise chisels are different than the regular paring chisels most people are familiar with. They're made for pounding into a piece of wood to cut a rectangular slot for tenon-and-mortise woodworking joints. So they're large and beefy. This design is a traditional pattern known as the "English mortise chisel". They stopped making them in the 50's, though there is at least one maker that recently started production.
I'm using 1/4" 1095 for this. Here's the blades after cutting and some cleanup:
I'm making 2 so I'll have one too.
So that was all pretty easy. On to the bolster! This was the usual kind of pain that comes with making square holes with round bits. I drilled a few 1/4" holes and then used a 3/16" end mill to clean it up. Followed by some awkward filing. I used 1/4" 1095 for this as well.
It may not be super obvious but the bolster isn't cosmetic, it's a load bearing part. The rectangular hole is flared front to back to match the taper on the front portion of the tang. This allows all the force of a hammer blow on the handle to be transmitted to the blade. Otherwise over time (or maybe immediately) the tang would eventually split the handle.
I'm pretty happy with the bolster fit. It's not the most perfect oval but it's not that bad. The bolster could be thicker. I think I will actually heat treat it and temper to something really low. I suspect these are usually made from mild steel but much thicker.
That's where I am now. Need to make another bolster for the 2nd chisel and figure out what I'm doing for the handle. Traditionally the handle is press fit onto the tang. This makes the choice of wood important so it doesn't split during installation. Hickory, beech, ash, red and white oak are the common ones used. What a boring list of woods!
Question: My thought was why not just epoxy the handles like I've been doing the wa-handles on my kitchen knives? My friend is concerned the epoxy might crack but I don't think so, I think it will actually be more robust than a press fit over the long haul. Anybody have any thoughts on this?
