Wire clip for native and caly jr?
Do they make a replacement wire clip I can get for my native CPmS30V and my caly jr zdp?
Thanks
I think fitting a wire clip to a Calypso Jr would take a considerable amount of work since it's set up for a three hole style. As for the Native, while the only clip Spyderco has ever used on the C41 is the flat steel barrel bolt style, it might be possible to fit the wire clip from a C78 Native III with a little judicious dremel work. Simple, compared to fitting one to a Caly Jr, but still not a "drop in" proposition.
Paul
My Personal Website - - - - - - A Beginners Guide to Spyderco Collecting - - - - - - Kiwimania
Dead horses beaten, sacred cows tipped, chimeras hunted when time permits.
Spyderco Collector # 043 - - WTC # 1458 - 1504 - 1508 - Never Forget, Never Forgive!
It's easy to grin when your ship comes in and good fortune and fame are your lot, but the man worthwhile is the man who can smile with his shorts twsited up in a knot. - Morey Amsterdam
I think you mean Native III and Caly3, both of which come with wire clips. You should be able to get a replacement from the factory if you call them up.
As for retrofitting wire onto a knife that had a sheet steel clip, it's probably possible, but would require modification as the Deacon suggested. Almost so much modification that you could replace the entire handle scales and/or buy the wire-clipped model for a similar price. If you don't want to do the dremeling, STR might take the job. See his forum under Makers.
