Withdrawn due to lack of interest
Feedback: +94 / =0 / -0
This light arrived last month - I put a battery in it, tested it, and decided I liked the other one I had been looking at better - so I posted it here. (This is a repost - the light has been back in the original box since day 1.) The only reason I'm posting it as "like new" is because I installed the pocket clip. Oddly, though purchased direct from a dealer, it did not come with any paperwork (but it's easy enough to figure out). withdrawn due to lack of interest
(US shipping only, at this price)
Please do not post in this ad! Contact me via PM or email. Redacted
I reserve the right to sell (or not) to whomever I choose; but, generally, the item will go to the first to claim it. Be advised that if you post in this ad, I will likely choose not to sell to you.
Here are the official details:
Features:
Superb light of amazing brightness due to efficient TIR-optics and no tunnel vision effect even after continuous use
Side switch for simple and comfortable one-hand operation and easy modes switching
Removable clip and possibility of tail-stand for multipurpose use
Compact and light-weight flashlight of guaranteed durability stands up harsh impacts and fallings from the 10 meters
Total protection from water, dirt and dust penetration flashlight continues to work even at the depth of 10 meters
Powered by recheargeable 18650 Li-Ion batteries for unlimited runtimes in all modes
Advanced modes operation and color temperature indication
Specifications:
Light & Optics Maximal light output: 1200 LED lumens
Beam distance: 150m
LED: Cree XM-L2 U2
LED Tint: Cool White 5500K
Optics: TIR-optics
Stabilization of constant brightness regardless of frost and low battery voltage: FULL
Hotspot: 20 °
Spill: 80 °
Impact-resistant glass lens with sapphire and anti-reflection coating:
Dimensions & Weight
Length: 110mm
Body diameter: 25.4mm
Head diameter: 25.4mm
Weight (without batteries): 65g
Body & Durability
Body material: Aircraft-grade aluminium
Body anti-abrasive finish: Premium type III hard anodizing 400HV
Premium antislipping matt surface treatment:
Body color: Matte Black
Waterproof and dustproof standard: IP68 (highest)
Waterproof & Submersible: 10m
Double O-rings for best waterproofing
Operation temperature: -25..+40 °C
Impact-resistant steel front bezel:
Bezel material: Stainless steel with ultrahard titanium coating
Protection of electronics by compounding it in aluminum capsule
Weapon Mountable
Anti-shock protection for weapon usage
Impact Resistance: 10m
Reliable spring construction for battery protection
Removable clip of stainless steel:
Trapezoidal threads for longer lifetime
Thread lubrication by Nyogel 760G (USA)
Tailstanding as a candle
Belt holster (Molle)
Strong and easily removable lanyard:
Modes & Electronics
Power source: 1x18650 Li-Ion / 2xCR123A / 2xR123 Li-Ion
Number of modes: 8
Type of mode switching: Side switch
Type of clicky switch: Electronic
Momentary activation for quick access
Advanced heat transmission for LED with copper MPCB
Advanced heat transmission for electronics
Active thermal management of LED and electronics
Special spring material for higher efficiency
Auto-memorization of the last used mode
Special signals (Strobe, SOS, Beacon)
Ability to save individual user settings
Built-in low battery indication
Built-in high temperature indication
Multi-color indication
Battery voltage indicator
Battery over-discharge protection circuit for unprotected batteries using
Advanced electronic reverse polarity protection
Light output without flickering
Ability to use batteries with a flat contact
Protection from accidental switch-on:
