I have two great knives up for your consideration. Both knives were purchased new by me and come with original boxes.
The ZT 0562 CF with 20CV has been carried and very lightly used. The only flaw I can see is a little rubbing on the clip near the screw hole which I captured specifically for you in the photos below. Otherwise this is in near new condition with a sharp factory edge, centered, great flipper action, solid lockup, etc.
ZT0562CF is yours for
The Spyderco Sage 5 has been lightly used to open packages, but that is about it. Factory edge is still very sharp. I did see a couple small scratches on the blade (clip side) just below the Spydie hole when I examined it closely, but barely noticeable in most light situations. I'm not sure how it happened since I haven't used this in any hard way but I captured it specifically for you in the photos below. Centering is good and the blade will drop using the compression lock with a little wrist flick. It has been disassembled once (using Wiha torx bits), cleaned and oiled. It is a smooth shut knife with a light blade so it doesn't just fall shut like a PM2 but is a very satisfying figitable knife. I also left the pivot screw slightly on the loose side so there is just a little blade play but better action IMO but could easily be tightened further based on your preference.
Here is a video link of the action showing both the wrist flick and shake shut movement: https://imgur.com/a/FeNgChq
SAGE 5 is yours for
First to post "I'll Take It" and specifies which knife gets it. PayPal G&S only. Shipped only to CONUS.
SAGE 5 is yours for
