- Aug 25, 2003
You guessed it. Yesterday at IG's (Wally World) we had a pretty productive day. Started out arriving aroung 10 AM, had to unload stuff from my car, beer, enough Kaowool to line 3 forges, and various other knife making things. The plan was to weld up a couple of forge bodies, 1 for Justin Mersier, and one for the raffle at IG's hammer in later this month. As I said, "enough Kaowool for 3 forges, well I've got a vertical that needs lining, I brought that along in case we had enough time to get that one lined, but we didn't :grumpy: . I also had planned on making a new pommel nut for damascus bowie that I've been working on, and making some damascus in IG's "Big Bertha"
I got the forge bodies welded up, IG and Justin took Justin's forge over to another area for lining, while I got Big Bertha ready for some "Steel Squishing". First off, was the new pommel nut, which was to be made with wrought iron. I welded a small piece onto a lollypop stick, again to be formed using Bertha, this ended be a total disaster, I'll never use a press again for trying to make something as small as a pommel nut,,hammer and anvil only (for me anyway
). IG had a billet stack (approx 23 layers of bandsaw and pallet strap, and end pieces (for thickness) of 1084. This billet stack had been sitting around IG's for ,,,,, I don't know, but it was rusty as heck (notice I refrained from using Hell on the forum). IG squirt it down with WD 40 the night before to help loosen oxidation in the initial layers.
I got this stack up to dull red and started putting on flux, wire brushing, for flux, brushing, then started using Boric Acid to really get into the layers and clean them out. I did the Boric Acid thing a few heats, then onto the regular flux and welding. The weld came out great (hopefully no inclusions), I streached this out to the length of IG's forge approx. 16", cut it and then the second weld, again it came out good. I streached it out to 16" once more and running out of time, left it in the closed forge (after shut down) for annealing. Next time at IG's, will probably be the Hammer In, where I'll finish this billet, and at that time I'll put in a few layer of Nickel.
After Justin got his forge all lined and coated with ITC100, he and Wa,,Wa,,Wally fired her up for the first time, I know IG took a few pics of that, and I'm sure he'll post some.
Wa,,Wa,,Wally made some chricio,shoe richeee
whatever.
So all in all, (with the exception of the pommel nut, things went real good at Wally World
