My cuz has a piece of snakewood enveloped in wax. Is this wood ready to go for a handle, or does it need to be stripped and dried. It's purdy, and we want to use it for a knife for a friend that just met hard times. Thanks all, Mike.
In a word
NO!
A lot of people have this assumption that when they buy wood its ready to use. If it is covered in wax, thats because someone waxed it when it was green! Never assume a block is dry if you dont have a reason to know it is "I.E buying old stock, having it sit around for a while"
and snakewood is THE WORST about cracking. Literally, i have never known a wood to be more finicky about cracking and splitting. I process my snakewood at least a year before hand, and most of my pieces have already been in the country for well over a decade.
Let it sit in your shop a while, you can take the wax off the faces but leave the end grain.
If you want to be sure your wood is 100% ready to use a on a knife, buy from a reputable seller of Knife blocks, Alpha knife supply, Burl source and myself all supply wood specifically meant for knives.
The best way to know if a block is ready for use is to test it with a moisture meter. 8% or lower is good, but if it is humid where you are that target may vary. If you don't have a meter, ask a friend who is serious about wood working if they have one and can test the block for you
