- Nov 28, 2014
I'm making my first wooden bolster. I am wondering what the rule of thumb on length is? 4:1, 4" handle and 1" bolster?
You want the bolster wood to be hard. Ebony, ironwood, bubinga, cocobolo, etc. I usually add a matching butt block. My blocks are about 3/4" normally. Some on a wa handle are about 1".
Are you doing anything special for the joint? Brass? Copper? Dovetail?
I think I'm going to try ironwood scales with the garage sale Macassa ebony for the bolster and see how it looks.
I am gonna do a liner of some sort. I'm also going to 45 the joint so when I round the handle the joint will have a curve in it. Hard to explain but maybe you can picture it.
I've only done the 1, but I'm partial to the compound 45 angle. It looks a lot more complex but it is just as easy to glue up as any other joint.I am gonna do a liner of some sort. I'm also going to 45 the joint so when I round the handle the joint will have a curve in it. Hard to explain but maybe you can picture it.
As far as the ratio, I think your pin placement is a major factor to consider. On most of my knives I use 3 pins and the ones with bolsters I normally try and stop the bolster halfway between the 1st and 2nd pin.
Chris
