- Nov 28, 2008
AA mini-mag dont work no more (4 yrs). can you guys reccomend a tough, simple, no bullshit, in the $40-50 range flashlite? will be belt carried. thanks . paul
Very good choice for the light. Will work really well. I have used the L2D for awhile as a general purpose light, and it's really good. The L2T has only the two most useful modes, and is a great light.Fenix L2T V2 Q2. Similar size to the AA mini mag you are used to. This is a simple 2 mode output light with the light level selected by tightening/loosening the head. Switches on/off via button on tailcap. Very simple to operate.
On low level, the light output is similar to your mag on fresh batteries. High mode will blow you away if you are not used to current 'bright' flashlights. $49.50 from 4sevens.com.
hey shooter, i.ve hasd the LED in the mini-mag for 2-3 yrs. works great, but for some reason it likes to turn itself on.????????? and i want a 1 hand pushbutton lite. you're right on the $10 worth of course. its just time to "upgrade". glad that MAG-LITE has set such a high standard. paulSide cutter: If I had of received 4 years of service from a $10 light, I would be overjoyed. I don't know if you are aware of it, but mini mags are now available with LED, or even at Wall Mart, you can get a easily installed coversion set up for about $6, which still makes for a very reasonably priced unit. I personally would elect for several of these, rather than one more expensive light which will hurt if it is lost or stolen. The LED version has tremendous battery life, plus is very bright also.
Just one person's opinion Merry Christmas
The problem with the Surefires is that they don't run on rechargeable batteries, and that means they get very expensive very quickly. Plus, (with the exception of the Aviator), the incandescent lights not regulated and dim rather quickly.I would recommend the Surefire G2. I have a G2 and a 6P(same as G2, but is aluminum instead of Nitrolon). They have served me well.:thumbup:![]()
But still relatively poor heatsinking, and dubious water-resistance.get the TerraLUX MiniStar2 TLE-5EX MiniStar2 EXTREME with CREE XRE-7090 LED for Mini Maglite 2AA , from batteryjunction $ 22
some recharegables
TerraLUX TCS-1 Tailcap Switch for the AA Mini Mag , also from batteryjunction $ 3.75
MiniMag Borofloat Lens - AR Coated both sides
$4.50 for extra light output,,from lighthound
and you will have 10x better mini mag light ,,more power with longer runtimes,,,
