I've used them all in the last year. All have their downsides. It depends on what you want. If you just need a working edge and don't want to spend hours sharpening, which for most people's average use is a 400-600 grit edge the Apex and Wicked edge are overkill. a Lanksy/KME etc. and a sharpmaker will give pretty good results under $150. I think the Apex/Wicked Edge is like Canon/Nikon, users just naturally gravitate toward one or the other after they've tried them. If you want mirror polished razor sharp edges the Apex/Wicked edge are the way to go, but for me that high of a polish on a blade isn't ideal for my everyday cutting needs.
The Worksharp is fast, but I could never get super consistent results with folding knives especially with thicker blades, I could get a knife sharp, even shaving sharp, but never as sharp and as even an angle as with the Apex or Wicked edge. I like to use a sharpmaker for maintenance and even after a lot of test knives and tweaking my technique I could not get the same angles on both sides of the blade consistently (Ex. I'd set it at 18 degrees and end up with 16/20). However not much is faster for getting a knife to the point that a few strokes on a sharpmaker to a working edge that will be ideal for most use. Honestly I'd buy one just for kitchen knife use, you can do a whole herd of them in 30 minutes scary sharp. Have to be careful though even the mid grit belts take off a lot of metal, if you sharpened with one regularly you could probably chew through a blade pretty quick unless you stick to only the finest belts.
The Apex I could never use the way it's designed. I could never get consistent results using one hand to hold/move the knife on the table and the other to sharpen it, and then having to switch for the other side. Especially as you get near the tip on folding knives, there's just not enough flat to keep the blade at the same angle. I ended up using it with magnets and wedges to keep the knife in one place. Again it's great for big knives with large flats on the blade, but a lot of folders these days don't have any big flats. It's time consuming and messy, most folders I do if you keep the stones wet expect to tear the knife down and clean it, and you have to true the stones after awhile. If it had an option to clamp blades, and had diamond stone options it would be a more universal unit I think.
The Wicked edge is a very expensive lansky on steroids (that's not a bad thing), again the clamp has issues with some blades, and there are various fixes, the diamond stones are great, but it's frankly really expensive, if you want the extra stones and upgraded hardware it's $700, you can buy a Lanksy, Sharpmaker, Work Sharp KO, and loaded Apex and still not spend $700.
Both the wicked edge and apex work best on large blades with flats on them, if you watch the product videos they usually work with a nice big kitchen knife with little belly, or a full flat grind, or a knife with large flats to clamp/rest on.
In the end they all will get great results, and they all have issues. There's still no perfect setup for every knife out there, the smaller the blade and the less flat surface the harder time most sharpeners have.
