- Dec 5, 2009
Hello all.
I'm working on my first knife kit from Texas Knife using a 6a SS blade and red/black dymondwood scales with stainless pins.
I have the scales glued and shaped to the edge of the tang and my holes drilled for the pins and I'm about to start roughing down the thickness of the scales. I have a couple questions at this point.
Should I go ahead and install the pins and glue them up now before scale thickness removal begins, or would it be better to add them a bit later?
and
What is a good average thickness for handle scales? The slabs I got from Texas Knife are pretty thick and I think instead of sanding the first bit of that thickness off, I could run them through the bandsaw to remove a couple layers. Is this a good idea? The scales are red and black layered diamond wood.
Thanks in advance for all the help.
and
