I am in the process of making a grinder based on the GIB, but using my grizzly for some of it. i have about 1/2 the materials i need and now looking for the 1/2" plate for the body.
for my modified design, using the griz for some of it, i figure i need 3 sheets of 1/2"x12"x12" (excluding the base) for the body and platen. i am using 12"x12" because i am thinking i can work with this size to get the smaller pieces the design calls for ..first question: will a basic metal bandsaw cut the 1/2" plate well enough to feasibly cut it down to size, w/o going through 200$ in blades? id prefer to have it plasma cut or something, but again $$$ is the issue. reason is, i dont want to take a 150$ grizzly, add 500 with it to get a grinder, i could have probably saved the griz and made a whole new grinder for that much. i added up the costs and depending on how much the metal costs i should have a pretty good grinder for fairly cheap.
Of course i am cheap and trying to spend as little as possible. ive been calling fab places, supply shops etc. here in houston looking for the metal. the problem is most are large shops not willing or able to deal in such small pieces. does anyone know of a small supply place near the houston area that might work with what i need? the places ive spoke with have like a 500$ min to cut on plasma or the like.
i realize that polar bear forge sells the plate for like about 250$ but i am hoping i can get out of it for alot less.
thanks in advance.
i am able to use the motor (adding pulleys) , tensioner and wheel set up, i had bearings machined into the drive wheel providing a large wheel attachment. i will probably reuse the tool arm pieces for something (new rest), and can reuse the angled platen for the flat platen attachment. the rest has been / will be purchased from various sources. almost there.
thanks in advance.
