I like knives with D2: wish there were more of them around. Does Spyderco has any with D2 blade: i have difficulty coming up with any model, I do not think they made a Mule with D2?
D2 is not stainless, and it was never meant to be. D2's 11-12% chromium content, along with its rather high carbon content (1.5%, give or take a couple points) is mostly tied up in carbides (for wear-resistance). There's some, but relatively little "free" chrome, which is what allows for passivation to occur and therefore, aids corrosion resistance. Depending on whom you ask, hardenable steels require 13-14% chromium by weight to be considered stainless. There may be exceptions to this rule, but D2 is not one of them.
Low-alloy steels constitute a category of ferrous materials that exhibit mechanical properties superior to plain carbon steels as the result of additions of alloying elements such as nickel, chromium, and molybdenum. Total alloy content can range from 2.07% up to levels just below that of stainless steels, which contain a minimum of 10% Cr.
Why is that a problem, Hwang? I'm relatively new around here, but I think I've seen you in sharpening discussions, so I guess you're probably more than good at it- is it looks of recurves, or something else?
Spyderco made 2 Sprint runs, The Military and the Para 1, you can still find the Para 1 at an online store in Canada. They were CPM-D2
I'm going to go against the flow here and say I would think long and hard about purchasing a D2 blade or any tool steel for that matter....IF!!! you live in a humid or wet environment (see next paragraph if you do). If you don't, D2 will serve you incredibly well. There's a good reason several hard-use knives, like Benchmade's Black class knives, use D2: it's a tough steel that won't quit.
I
HOWEVER! If you live in a humid environment, D2 will punish you for carelessness. I live in a very humid environment (humidity index often reaches 100% right up through September) and I've had problems with keeping my D2 blades free of rust. I have taken excellent care of my Benchmade 710- D2, applying oil to it every morning, making sure to oil up the interior, ect, and I still have problems with small rust spots forming. The same goes for my Brous Silent Soldier necker: despite oiling it up frequently, a tiny rust spot or two still manages to make it's way onto my blade. I've recently taken to applying a very light coating of Vaseline to the blades, which seems to do the trick. Still, it's a big annoyance, and one that has caused me to put off my plans of buying any more uncoated D2 blades (coated D2 should be fine) for a long time.
In summary, let me say that I am not hating on D2; it's a fabulous working steel that will take hard-use like a champ. I once heard it said somewhere that D2 "can take any edge, crappy or good, and hold it for a long time". In my experience, that's true. If you need a steel that you can thump on and brutalize, D2 is hard to beat...but heaven's help you if you want it to look prim and pretty at the end of the day.
Just my .02...not trying to be a hater.
Knarfeng, I'm sure you are correct technically, but my understanding is, that's a bit out of context when discussing hardenable alloys suitable for knife blades.
Please review my earlier comments regarding carbon content, carbide formation, and the need for "free" chrome (that is, chrome not tied up in carbides) to allow martensitic steel to be generally considered "stainless" by the knifemaking and toolmaking industries. If I am incorrect in those specific regards, I sincerely welcome further clarification.
I apologize to the OP and other respondents for Knarfeng and I drifting somewhat off-topic.
The short answer remains, YES, D2 with good heat-treatment can be used to make a good pocketknife.![]()
