So I got a question for the 5160 aficionados in the room. Making a hunter from 1/4" thick 5160 bar stock, stock removal only. Shape cut, bevels done, and surface finished to 500 grit. Did the heat treat in 130°ish canola oil. HT twice (bright orange just above non-magnetic) because I wasn't satisfied with the file test. Tempered twice for 1 hour at 375-400°.
That done, ground off the scale and started on the finish and along the spine, back by the ricasso, there are some shallow ripples running parallel to the spine. I didn't see the defect before HT. Is anyone familiar with this happening? There are only 3-5 ripples/wrinkles per side.
Is this only going to be a cosmetic problem to try and cover up with a patina and flat finish or is my steel toast?
