Ws Damascus Bowie WIP
Had a moment to post a little progress this morning.
The focus here is to apply a little basic math and geometry.
Everything is calculated from center lines, and I make a lot of use of my French Curves.
Create the basic profile of the guard and butt cap.
Center and pin.
Notice that the handle material is still in its basic 2 dimensional configuration and no 3 dimensional shaping has taken place - yet.
I will now use the guard and the butt cap to guide me as I file the handle to shape.
That process practically eliminates mistakes.
That way I'm not "chasing" anything and trying to make things line up.
After I get the largest % of handle mass removed, I will switch to finer cut files and gradually float everything together.
But, that's later on this afternoon.
Actually, the next project is to turn the permanent pommel screw.
GIDDY UP!
I have learned much from this thread!:thumbup::thumbup::thumbup::cool:
Now with my guard and butt cap profiled, pinned and centered, I can use them as my guides for shaping the handle material in a "connect-the-dots" fashion:
All I need do is shape the handle to the pieces already shaped:
This is the knife with the basic handle shape completed, but still sporting the temporary pommel nut:
Remember that recessed step in the butt cap? (Look back if you don't remember)
That shoulder was .088" deep.
So, here I cut in the mating shoulder on the pommel nut, but I create a step .100" long - .012" over the step depth.
This is because the butt cap will be hot blued and I positively don't want any contact going on that will be visible - so that gap there is .012".
Ready for hand sanding on the Walnut, finish sanding of the hardware, hot-bluing of the blade and hot-bluing of the hardware.
Guess I know what I'm doing tomorrow!
Looking good Karl!
Thanks for doing this WIP. I appreciate all the extra time you are taking to share this with us!
I am glad to see you doing the WIP on this particular blade -- especially since I saw it when it was nothing more than a bunch of steel bars laying on the bench :)
Brian
Looking good karl - I didn't realize you had planned to blue the blade. Please give us some close-ups of the blade steel before and after bluing so we can see it's visual impact on the damascus pattern.
Roger
Another day.
Here's a close-up of the hardware assembly and the blade, both in un-blued condition.
And here is a picture of a VERY boring Damascus blade hung in a cradle about to be hot blued:
Here we are coming up to the target temp of 292 degrees:
Roger, I just remembered you wanted a closeup:
For those unfamiliar with the hot-bluing process I'm using here, it is the same procedure as used on many of your favorite guns.
It's a controlled oxidation of the steel surface.
These bluing salts are AMAZINGLY caustic!!
They do what they are supposed to do at a rolling boil maintained at 292 degrees.
Here's where your high school chemistry comes in!
We control the boil at 292 degrees by controlling the specific gravity of the mixture.
You know how water boils at sea level at 212 degrees - right?
Right.
However, take a dip of the sea water itself, and it won't boil until you raise the temp of the mix a ways.
It's because of the specific gravity of the mixture.
This mix here is SO heavy, because of all the salt, that it won't boil until it gets to 292 degrees when the mixture is correct.
It's a real ballet/dance.
If the mixture is boiling either under or below 292, the bluing job will be affected.
So we control the boiling temp of 292 by the addition of either water or salt.
And we need to maintain that temp for 30 minutes!
So, as time passes by, water escapes as steam and the mixture becomes heavier = a higher boiling temp that is NOT acceptable.
So, we need to gradually replace the dissipated H2O as we go along.
We don't regulate temperature by the flame, we do it by adjusting specific gravity.
In this case today, it started boiling at too low a temp, so I had to add salt.
Anyway, here it is, boiling away at the target temp with the blade suspended:
I did feel it necessary to mention that all of the water involved in this process must be very pure - no tap water, well water or distilled water.
Any unwanted mineral in the water may adversely affect the salts and neutralize them.
So, each winter I collect about 10 gallons of melted snow.
Even distilled water may have been distilled in copper lines, or rain water from your gutters will have spent time in aluminum!
Not good.
After 1/2 hour, the blade is removed and quenched in cold water to set the bluing.
Then, it's suspended in boiling water to dissolve any residual salts.
Then suspended in water displacing oil.
Then, since the salts don't differentiate between nickel bearing steel and non-nickel-bearing steel, the blade comes out totally black!
When I etch Damascus, it gets a REALLY deep etch that leaves the nickel bearing steel up higher than the other.
So, after hot-bluing, the blade is sanded with 3000 grit to remove the bluing from the 15N20 in this case.
Then polished.
This was a differentially treated blade and you may be able to see a light difference, which to be quite honest, is even LESS visible in person.
The lighting just catches it differently.
Now, to do the hardware!
Looking VERY good Karl. Thanks for taking the time for pictures and to explain the various processes.
Peter
I had to post these on another site and since I was in the computer chair, thought I might toss them on here as well.
Sorry about the lint and the smudges - it was just an impromptu post to demonstrate some different views:
Beautiful. And your explanation of the Blueing process is icing on the cake.
Thanks for sharing.
Mitch
Karl that is cool and I learned a good deal on the hole salt blueing thing Thank you
