WTS: KV-04S (SOLD), BRKT sheath (SPF), like new Mountain Hardwear Trad pack (SPF)
Feedback: +36 / =0 / -0
Hi-
I have several random items available, someone should use them.
SOLD and shipped --- First is a used K-VAR KV-04S optics mount for the AK platform. It shows a little wear, is fully adjustable, features a quick release/return to zero, and is knows as one of the most solid options available. Asking for $70 shipped. (pic shows it is oily) ---SOLD
SPF---. Second is a black leather Sharpshooter sheath for a Bark River Knife and Tool Bravo-1. It is used, I purchased it used (never bought the Bravo-1) and the leather retention strap has been cut. It still functions, the cut does not go all the way through, but it is close. If you epoxy it, that may help. I will let it go for $20 shipped. It is easily worth it if you're looking for one. ---SPF
SPF---. Finally, I have a Mountain Hardwear Trad backpack, grasshopper color, new never used. I did check it out/try it on/pack it up with some gear, but it has just sat here so far and I probably won't use it. It is a lightweight hiking pack, size is large. Asking for $100 shipped. PRICE REDUCED, asking for $75 shipped. MSRP $130 ---SPF
Description copied from Altrec.com, the place that I purchased it from:
"Fully ventilated spacer mesh backpanel and hipbelt deliver a comfortable carry, daisy chain and full wrap compression straps for strapping on gear. Extra-beefy 630D Cordura® Ballistic Nylon bottom and tough 420D HD Nylon front panel resists damage from rocks, ice and tools.
Specifications
Body Fabric: 210D HexNut Ripstop Nylon
Hard wearing 630D Cordura® Ballistic Nylon bottom resists damage from rocks
Removable HDPE framesheet with alloy shaping rod for load support and customized fit
Padded air mesh backpanel is cool and comfortable
Contoured, dual density shoulder straps
Fixed, padded waistbelt with two zippered pockets
Top loading with fold top design allows use with lid pocket removed
Tuck-away full-wrap compression system is makes it easy to lash on a very wide range of gear
Side zip on left side for additional access to upper pack
Hydration sleeve with external access for easy refilling
Upper flap pocket for smaller items
Two pockets in removable top lid
Full front daisy chain and fixed heavy webbing ski loops
Usage: Trekking / Hiking / Climbing / Backcountry
Capacity: 2400 cu. in. / 39 ltr.
Weight: 3 lb. 4 oz. / 1.48 kg.
Torso Range: 18.5 in. - 22.0 in. / 47 cm - 56 cm
Dimensions: 28 in X 13 in X 11 in / 71 cm X 33 cm X 28 cm
I can take pics for anyone interested, PM or email me with requests/pictures. Shipping is included for USA, if you want me to ship outside USA we can talk but you will assume all responsibility for any losses. I can take PP (3%) or USPS MO, along with other/checks with time to clear the bank. Not really looking for trades at this time, but I will consider factory (230gr FMJ) 45acp ammo, and a fine/ultra fine ceramic or water bench stone.
