- Nov 19, 2003
This is a 2010 model folding mountain bike 20in frame 26in rims has a few scratches from my bike rack other than that everything work's as it should.Has a Cloud 9 gel seat and Shimano pd-a530 pedals.500.00 shipped.
Clever integration of the patented CLIX System allows for the Paratrooper to be folded in under 20 seconds without the use of tools. A flip of the CLIX quick release lever on the top tube and the bike folds to a compact size.
Specifications
Color Matte Cammy Green
Frame Custom drawn 7005 Series Aluminum with FIT System. Power Angle geometry. Replaceable derailleur hanger and disc mount.
Fork SR Suntour. Suspension XCT V2. 80mm travel. Alloy one piece lower. Disc Compatible.
Rims Jalco. Alloy, 32 hole. Double Wall. CNC Sidewall.
Tires Kenda. Knobby. Front and Rear Specific. 26 x 1.95*.
Hubset Formula. Black. Alloy. Disc Compatible. Sealed front & rear with CLIX front quick release.
Spokes 14 Gage.
Saddle Mountain with *Center Gap* Comfort Technology.
Seatpost Kalloy, 27.2 X 300mm Alloy.
Handlebars Kalloy. Alloy. 7 degree backsweep. 31.8 Barbore. 580mm length.
Stem Kalloy, Alloy Direct Connect. 31.8 Barbore.
Shifters Sram X-5 Trigger Shifter.
Front Derailleur Shimano Top Pull.
Rear Derailleur Sram X-5.
Crankset SR Suntour. 42/32/22. Alloy 170mm crank arm. Matte Black.
Speeds 24 Speeds
Brakeset Promax. Front & rear mechanical disc w/ pad adjustment. Alloy Levers.
Pedals Platform pedal with alloy cage.
Bottom Bracket Sealed Cartridge
Frame Sizes 18", 20"
Stand over heights 30*, 31*
Folded Size 36" x 28" x 12"
Approx Weight 29lbs.
MSRP $879.00
I found out i am no collector ,i need guns i am not afraid to scratch so looking to sale or trade this off.
Ted Yost Browning
>Hi-Power in 40S&W?
>this pistol has a number of features beyond the standard Yost SRT
>conversion, including a built-up beaver tail grip; deluxe trigger job with
>polished / radiused trigger, tool steel sear, and skeletonized commander
>hammer; flattened / serrated slide top, gold line front sight, YoBo rear
>sight, 40 lpi mag release; and hand-fit Spegel grips
>comes with two mag's
> the custom work alone would cost more
>than $3000 (in 2007) with an 18-24 month wait. it's priced at (($3,000)) us mo only on this one
round count under 500 (THREE DAY INSPECTION IF YOU DON'T WANT IT SEND IT BACK I SEND YOUR MONEY BACK).
> Trades ,looking for + or - cash will entertain multi gun deal, you never know till you ask
>Custom 1911"s
>AR'S 5.56 OR 7.62
>woa setup for high power or JP Enterprises
>fulton/LBR full usgi m1a
can send more pic's by e-mail.
Only opened to check contents never mounted........750.00OBO shipped
TRIJICON TR22-1G 2.5-10x56 ACCUPOINT RIFLE SCOPE - Standard Crosshair with Green Dot
The largest and most powerful Trijicon riflescope on the market, the TR22 AccuPoint has extreme light gathering capabilities with a huge 56mm objective lens, 30mm tube and the highest quality glass available. The scope is illuminated though the use of fiber optics and tritium, providing a vivid aiming point without the need for failure-prone batteries. If your hunting calls for long distance shots, this AccuPoint is for you.
The TR22-1G also includes:
1 Trijicon Logo Sticker (PR15)
1 LENSPEN® (TA56)
1 Set of Lenscaps
1 AccuPoint Manual
1 Warranty Card
Specifications:
Magnification 2.5x-10x
Objective Size 56
Bullet Drop Compensator No
Length (In) 13.8
Weight (oz) 20.7
Illumination Source Fiber Optics & Tritium
Reticle Pattern Standard Duplex Crosshair
Day Reticle Color Green
Night Reticle Color Green
Eye Relief 4.1 to 2.8
Exit Pupil 16.3 to 5.6
Field of View (Degrees) 7.18 to 1.94
Field of View @ 100 yards (ft) 37.6 to 10.1
Adjustment @ 100 yards (clicks/in) 4
Tube Size 30mm
Housing Material 6061-T6 aluminum, hard coat anodized per MIL-A-8625, Type III, Class 2 dull & non reflective
payment by pp + 4%(or gift) on the scope & bike us postal money order on the BHP
Specifications
Spokes 14 Gage.
Speeds 24 Speeds
MSRP $879.00
Ted Yost Browning
>Hi-Power in 40S&W?
>Custom 1911"s
>AR'S 5.56 OR 7.62
1 LENSPEN® (TA56)
1 Set of Lenscaps
1 AccuPoint Manual
1 Warranty Card
Specifications:
Objective Size 56
Length (In) 13.8
Weight (oz) 20.7
Tube Size 30mm
