WTT Busse for Strider
Feedback: +5 / =0 / -0
I'm looking to trade my Busse Sarsquatch for a Strider. TRADED!!!
I also will throw in a Surefire M3 Combat light with a multi lock sheath by nighteyes.
[/IMG]
The M3 is a high-output flashlight featuring a Combat-Grip™ body and special shock isolation for its incandescent lamp to reduce the chance of failure from impact or vibration. It uses a precision micro-textured reflector and a SureFire incandescent lamp to produce a smooth, brilliant beam with more than enough power to temporarily blind and disorient an aggressor by impairing his night-adapted vision, or to reach out and illuminate distant objects and areas. Output is either 125 or 225 lumens, depending on which easy-to-install lamp you use—high-output or ultra high-output. The tactically-correct pushbutton tailcap switch provides secure, ergonomic activation control: press for momentary-on, twist for constant-on. The M3's patented CombatGrip™ improves performance with various flashlight/handgun techniques, such as the Rogers/SureFire technique, and provides a secure grip in wet or cold conditions. CB model available with crenellated Strike Bezel®.
I am looking for these Strider models,
GS-GG, MT-MOD10 SNIPER, MT-SS, BG, MV (Double edge ), CP, RW-2, PH, MM DAGGER, EOD Model, SLCC-GG, GW/AR-S, MFP-GG, WB MOD-10, MD, DB-L, HS, PS, MB, JW, MFP, GG, SA-L, ?????????????
If it's a Strider then chances are I'm interested unless it's a folder. Outside of Striders I'm not really looking for anything other than a Busse WarBoar.
If you feel you have something not on the list that would perk my interest then go ahead and pop me an email.
You can reach me at lat_mallonee@yahoo.com You can also reply here but I will not get emails.
I have a good as new Strider MB that has only cut a little tape and my right arm (don't worry, my arm didn't hurt the edge at all)
I am a Busse geek and the Sarsquatch is at the top of my list-and who couldn't use another surefire. Let me know if you're interested.
