Unbreakable
Banned
- Sep 21, 2002
OK... I have a few knives here that I want to put on the market. They are both lightly used but in VERY good condition. And they both have sheaths.
1st is a Mole Jack. It's been sharpened and stropped probably about 5 times. Used mostly for outdoors chores. It has a few coating dings around the choil and talon area. On small finish chip just behind the edge. Nothing major... I'd say it's in 97% as far as looks go and 100% in funtion and form. No chips, dings, nicks, or dents in the edge. The edge is perfect. Has crazy swirl marks in the coating as you can see in the picture... don't know what it is... It was always like that. Comes with Spec-Ops brand sheath... The expensive on and not the basic one. Has the zippered front pouch. I removed the srew and in the bottom and replaced it with two zip ties... I did this because the Satin Jack tip was going to make contact with the metal bolt and I would rather it sit atop plastic than metal. The Kydex skeleton is held tightly in place and the ties are every bit as good as the bolt.
2nd is a Skeleton Warden. This was one of the earlier models so I'm told it's slightly thicker than most of the others. This knife hasn't been used so much as marked by the makeshift sheath I have for it. The sheath is the lower half of another sheath I had that I cut to fit the SW. It works great and with a little tightening it would be perfect. I wrapped the handle with 550 cord. There is a minor mark in the finish near the spine that the knife came with and it has minor rube marks from the sheath fitting tightly around it. Other than that all I did was touch up the edge to get it sharp.
Contact me at cdgilbert@alltel.net
The only trades I'm looking for are short barreled ruger or S&W revolvers in 44mag, 454 or BFRs in 45/70 or 450 Marlin. Or Armalite AR-10 Upper. I can add cash of course if needed.
Or other Busse knives like a FFBM, Police Recruit, Badgers, NO-E, Mean Street and the like. Plus or minus cash depending.
And of Course Large thick bladed knives by quality manufacturers or makers. At least 12" or better and at least .25" thick.
