WTT Edge Pro Apex
pf1
Feedback: +5 / =0 / -0
TRADEDI have an Edge Pro Apex that I got a couple years age from TAD gear. I have used it a dozen times or so.
It has the following grits:
1x the coarse stone that the writing as worn off (I think 120)
1 x 180
1x 220
2 x 320
1x 600
The grit is readable on all the stones minus the coarse.
I also have the blank with the 3000 grit tapes that I have never used.
I have the following that came with the system:
Instructions
leveling sand (never used)
2x cloths
ceramic rod
the edge pro base and rod
the carrying case.
I am trading because I went to convex edges and sandpaper so the Edge Pro just sits. TRADED
EAGLE A-III Pack: OD Green. Bought in 2004, used in Afghanistan a couple times then sat in a box. Used but good condition. Have plastic pack frame in it.
SOLDBlack Hawk Omega vest. OD Green. It is similar to this one except it has a firstaid/compass pouch on the left shoulder side. http://www.blackhawk.com/product/Omega-Vest-Tac-ShotgunRifle,1133,85.htm SOLD
I can send pics on request.
I am looking for RAT Cutlery in particular but may be interested in any similar utility style fixed blade. Used is not an issue. Also might be interested in XD/XDm accessories, smaller packs, fire starters, etc.
Paul
i have a 4.5" marble ideal with LE maple burl handles from AG russel that is like new. the sheath has been slightly modified to take a tek lock.
Hi,
I have a Tanto Herbertz about a foot long razor sharp with looks like a Rosewood handle and a Brass hilt and end cap with a hole for a Lanyard and a Tops Magnum 711 CQT here's the specs if your interested, I also have pics.
:confused:
CQT Magnum 711
$229.00
Blade Length: 4 1/2"
O/A Length: 10"
Cutting Edge: 4 1/2"
Length Closed: 5 3/4"
Thickness: .140 stock 5/32"
Blade Steel: N690Co / Cobalt Vanadium Steel
Blade Hardness: RC 58-60
Blade Color: Military Grade Black Teflon
Handle Material: G-10
Liner Lock: 420-J2, RC 48-49
Spacers: 303 Stainless
Sheath: Ballistic Nylon-Molle Compatible
Design: Patent Pending
MADE IN ITALY
Hi,
Not interested in folders.
Thanks though.
EDGE PRO is either traded to Type00rev or sold to another member.
Blackhawk Omega Vest is sold.
Received the EdgePro today......everything is good to go :thumbup: Email me when you get your package.
