Looking to get a Strider GS and I'm willing to trade singular or package deals depending on handles ( gunner grips or paracord ) and wear and tear. Used is okay though if you have taken care of it.
As a package I have a Spyderco civilian with the carrying pouch. Specs are.
G-10 handles, VG-10 steel, 4 1/8 in blade length, 1/8 blade thickness, lockback.
Pic is not mine but blade is in great condition 95%.
[/IMG]
Also a Surefire M3 combat light.
Specifications
Output / Runtime
MN10 Lamp 125 .0 lumens / 60 minutes
MN11 Lamp 225 .0 lumens / 20 minutes
Length 7 .30 inches
Bezel Diameter 1 .63 inches
Weight w/Batteries 7 .0 ounces
Batteries 3
123A
Description M3 Models
The M3 is a high-output flashlight featuring a Combat-Grip™ body and special shock isolation for its incandescent lamp to reduce the chance of failure from impact or vibration. It uses a precision micro-textured reflector and a SureFire incandescent lamp to produce a smooth, brilliant beam with more than enough power to temporarily blind and disorient an aggressor by impairing his night-adapted vision, or to reach out and illuminate distant objects and areas. Output is either 125 or 225 lumens, depending on which easy-to-install lamp you use—high-output or ultra high-output. The tactically-correct pushbutton tailcap switch provides secure, ergonomic activation control: press for momentary-on, twist for constant-on. The M3's patented CombatGrip™ improves performance with various flashlight/handgun techniques, such as the Rogers/SureFire technique, and provides a secure grip in wet or cold conditions. CB model available with crenellated Strike Bezel®.
[/IMG]
I have both bulbs and the box plus a Nighteyes belt hoster with multi position lock.
I will also throw in a CS Desperado AND a SafeKeeper 2 ( no pic of the CS SK2 but it is in like new condition ) just as a freebie. It is old but has life left still in it.
[/IMG]
This is a great package deal for anyone who is willing to put a GS in my hands 3 KNIVES AND A GRAIL FLASHLIGHT!!!
As a singular trade I have a Busse Sarsquatch with the finish removed.
[/IMG]
You can email me at lat_mallonee@yahoo.com
ONLY LOOKING FOR A GS!
Specifications
Output / Runtime
Length 7 .30 inches
Batteries 3
123A
