WTT: Kershaw, Leatherman, oakley radars, for esee, Bk-7, folders, etc.
Feedback: +22 / =0 / -0
Hi all-
Pics available upon request.
Email is quickest.
First up is a very lightly used Kershaw skyline.
Carried about 5 days as a secondary blade and used to cut a piece of string. Blade and clip are pristine, and show no marks, scratches or otherwise. The G-10 shows some light scratches. W/ slightly battered original box.
Specs from kershaw website:
Steel: Sandvik 14C28N stainless steel with stone-washed finish
Handle: Textured black G-10
Blade Length: 3-1/8 in. (7.9 cm)
Closed Length: 4-1/4 in. (10.8 cm)
Overall Length: N/A
Weight: 2.3 oz.
[/COLOR]
Traded
Next up is a Brand spankin new leatherman "tool".
Features
420HC Blade
Awl
small, Medium and large flathead
File
Bottle/can opener
medium phillips head
needle nose and regular pliers
Hard and soft wire cutters
8" ruler
lanyard hole
Number three is a user victorinox one hand trekker
from the Vic site:
One-handed semi-serrated locking blade (liner lock)
Bottle opener with large locking screwdriver & wire stripper
Can opener with small screwdriver
Phillips screwdriver
Key ring
Toothpick
Tweezers
Reamer
Wood saw
Life time warranty
Handle scales are scratched
and the blade has been sharpened once.
The tools have a few light scratches but the only thing that has seen real use is the saw.
No Box or sheath
Fourth is a New unused and uncarried Leatherman monarch 400.
This is a bright little sucker!
Specs:
45 Lumens
1 hr Battery Life
3W LED
Anodized Aluminum Body
Anodized Aluminum Bezel
Polycarbonate Lens
Plated, Textured Reflector
Tail Switch
White Light
One On/Off Brightness Setting
AA Battery (Included)
-32F/+140F Temperature Resistant
Water Resistant, Rated IPX4
Humidity Resistant
Corrosion Resistant
Shock Resistant
Circuitry Management for Regulated Light Output
Hole for Lanyard Attachment
10-year Warranty (Does Not Include Battery)
Last but not least is a pair of Oakley radars livestrong edition.
Lenses have some scratches but they cannot be seen while wearing these fantastic glasses.
About one eight of an inch of the left tab that holds the lens in the Frame snapped of but this does not compromise integrity off the glasses.No matter how the glasses are flexed while wearing the lense still stays in the frame. I guess Oakley over-engineered there glasses. That part of the lense is obscured by the frame so it does not detract aesthetically either. If this bothers you oakley offers replacement lenses. A small patch of paint has fallen of from the frame above the nose piece but the frame material is the same color as the paint so you can only see it up close by the change in gloss.While wearing that patch is facing your forehead so it is not visible to you or anyone. Ships with white array case and matching microfiber bag.
I would like to trade these as a group.
i am intirested in production folders and large fixed blades.
Also, good flashlights and some maxpedition packs.
Would love a damascus case peanut!
Cheers,
Adin
