BRKT Bravo 1 is in very good condition. Has seen a little use which is the reason for trading it. It has A2 tool steel, is very sharp, has white micarta scales and comes with the kydex sheath.
Overall Length: 9.065 in
Blade Length: 4.250 in
Blade Steel: A-2
Steel Thickness: .215 in
Weight: 7.375 oz
Hardness: 59RC
Spyderco Paramilitary is LNIB and hasen't cut anything. It is the camo/DLC combo. Blade is centered. Also the compresion lock doesen't stick and it is very smooth. Comes with the box. The only reason I'm trading it is that I'm looking for one without camo scales.
length overall 8.281 " (210 mm)
blade length 3.438 " (87 mm)
blade steel CPM S30V
length closed 4.812 " (122 mm)
cutting edge 3.078 " (78 mm)
weight 3.75 oz. (106 g)
hole diameter .563 " (14 mm)
blade thickness .141 " (3.5 mm)
handle material G-10
The knives I'm looking for (I don't mind users):
-Fallkniven F1
-other Fallkniven knives
-Spyderco Caly 3.5 Super blue
-Spyderco Para2 (regular black/satin blade,) or sprints
-Spyderco Manix 2 sprints
-Spyderco Dragonfly H1
-Spyderco Ladybug
-Bushcraft/survival fixed blades under 4 in
-Smaller EDC folders with premium materials
-I might consider Benchmades and other knives
This are most of the knives I can think of right now. You can also propose anything else. If you have any questions feel free to ask. You can contact me via visitors message or email:
miha(dot)gale(at)gmail(dot)com
Blade Steel: A-2
Weight: 7.375 oz
Hardness: 59RC
-Fallkniven F1
-Spyderco Ladybug
