- Jun 15, 2009
TRADED TO RILEY NYE.
I have a Protech backpack for trade. This pack is a top quality pack that I just haven't found a spot for in the gear I use. It has been stored since I bought it, the only thing I did was secure all the extra webbing so it wouldn't flap around.
Trade for Blur, Cryo, PM2, Izula II... etc. Just let me know what you have to offer.
Protech Engage:
Abrasion resistant material that will not tear
1800 cubic inches of storage space
Dual zip main compartment measures 8”L x 3 ½”W x 16”H
Main compartment has internal compression straps
Dual zip front 16” x 9” pocket
Front pocket has internal Velcro™ plastic pocket
Side entry zip 14” x 9” pocket
External hydration compatible access
MOLLE webbing on front and sides of pack that allows you to customize your pack with adding extra pouches as desired
Padded and adjustable shoulder straps
Spacenet back panel and pads provides quicker moisture evaporation and helps prevent heat buildup
Sternum strap snap fastener
Padded waist belt with snap fastener
Heavy duty concealed SDS Katana quiet nylon zip pulls
Heavy duty “D” rings
Left or Right neoprene radio ports
Custom Fit Suspension System is designed to provide the ability to fit each individual body type through two easy adjustments
Top carry handle
Stiff internal frame
Here are some pics of the actual pack, it is black and I gotta say it is a really nice trim (1800 CI) backpack. The fabric is really tough but isn't stiff like the Maxpedition packs, the ergonomics are well engineered and there is a breathable material used on the shoulder straps and back that is the coolest material I've seen in a long time. If you're going to be walking then this pack is a great choice because it has really nice waist straps compared to the others.
Stock Image:
Protech Engage:
Top carry handle
Stock Image:
