WTT- Spyderco Harpy for a ZT
pwerfel
Feedback: +42 / =0 / -0
I offer this used SPYDERCO HARPY ~ C08
Please Select:
Harpy SS-SpyderEdge
length overall 6.5" (165 mm) blade length 2.75" (70 mm) blade steel VG-10
length closed 3.875" (98 mm) cutting edge 2.563" (65 mm) weight 3.9 oz (109 g)
hole diameter .469" (12 mm) blade thickness .125" (3 mm) handle material Stainless Steel
Spyderco Harpy
Like the claw of the Harpy eagle the C08 is shaped for controlled pulling cuts. The hawkbill blade shape originated in the marine/fishing industry where severing rope, line, webbing and netting is done at arm's length quickly and efficiently. The curving arc holds what you're cutting against the sharpened edge keeping it from slipping off the tip.
Custom knifemaker David Boye developed the dent in the locking lever, which insures the blade remains securely locked open when gripping the handle with force. Cut out of the handle is a shackle key/drying vent allowing air to circulate around the blade when closed wet. Metal clip is positioned for tip down carry.
Please email paul.werfel@stonybrook.edu
