- Nov 13, 2004
TRADE for - NIB LX2 SureFire LumaMax ( 15/200 Lumen )
OR
NIB - PE Spyderco folders - C63G3, FB4, C36GBK, C103G, C81GBK,
Traded
Spyderco Military Safety Orange G-10
Sprint Run! 600 pieces
A cornerstone model in Spyderco's Save and Serve line up is the C36 Military Model meeting the requirements of a high-performance, light-weight folder designed for hard use. Since the steel is the spirit of the knife, CPM®-S30V with almost 2% carbon seemed the logical choice for the blade given its reputation for long-term edge retention and rust resistance. The 'Millie' has a modified clip-point blade laser cut with a 14 mm Spyderco Round Hole for quick deployment and for use with gloves. Jimping above the hole hold the thumb in contact with the blade's spine during cutting for confident control over the sharpened edge. The handle scales are Safety Orange G-10 with the lock's liner nested (inlayed) directly into the scale, pumping up lock strength without the addition of bulky liners. Spacers between the scales create a gap running the handle's full length exposing the inside workings for inspection and cleaning. The handle flares slightly at the front end creating a finger choil and at the butt end, which keeps the knife from slipping forward or backward in the hand while sawing or making tough or aggressive cuts. A contoured stainless metal clip is set for right-hand tip-down carry..
Specifications
• * Length Overall: 9 1/2" (241 mm)•
• * Length: Closed: 5 1/2" (140 mm)•
• * Hole Diameter: 9/16" (14 mm)•
• * Blade Length: 4" (102 mm)•
• * Cutting Edge: 3 11/16" (94 mm)•
• * Blade Thickness: 5/32" (4 mm)•
• * Blade Steel: CPM-S30V
• * Weight: 4.25 oz (120 g)•
• * Handle Material: Orange Peel-Ply G-10•
• * Made in Golden, Colorado USA, Earth•
OR
Traded
Specifications
