WTT: Two Cold Steel Arc Angel Balisongs And Busse Skeleton Warden
Unbreakable
Banned
Feedback: +2 / =0 / -0
Got two of these. One Spear Point and One Clip Point. The clip point is thinner but wider while the spear point is a little thicker. For this reason the Clip point seems to have a touch more play in the handles... but nothing major and they could always use a washer up grade to improve overall play. The spear point is TIGHT when you clasp it... closed or open. The Clip point will clasp fairly easily closed but is also very tight when open. Both are In like new condition. The Clip is a little older and has a little more use but I'd rate it 97% while the spear is a strong 99%. I have boxes for both.
I also have a Busse Skeleton Warden... I like it... but would rather have one with micarta scales. It was one of the earlier thicker ones... I think it's around .18" or .20". It's got one streak in the coating near the spine... It came that way. The knife is unused.
I'm open to a good bit in trade. The only folders I'm interested in are a Spyderco Manix PE, Spyderco Spyderench PE, or a Bencmade RUKUS with PE, or a Benchmade Balisong in S30V.
Could always use good quality fixed blades, Cold Steel SRK, Recon Scout, Stainless or San Mai Tantos, Outdoorsman, Busse little guys like the skeleton key or wardens with scales, Or the whole lot for something larger like a Mole Jack or AD. Swamp Rat, Scrap Yard, Nimravus in M2 spear PE, Martindale 24" machetes... Open to a lot. Just email me at cdgilbert@alltel.net
