Wuben E01 flashlight uses aluminum alloy material, it is non-slip, waterproof, and abrasion resistance. It utilizes Cree XPG3 LED, powered by AAA battery, with 3 output levels, maximum 100 lumens, all controlled by the tail switch. High, medium, low, SOS, four modes, so many brightness options are convenient for us. LED will give you stable and bright light, nonthermal radiation, safe and reliable. It is suitable for camping, fishing, hunting, hiking, searching, working.
Brightness Levels and Runtime:
High: 100lm ( 1h )
Med: 20lm ( 5h )
Low: 1lm ( 20h )
SOS: 20lm
Product Features:
● Hard anodizing hoursing
● Utilizes Cree XPG3 LED, lifespan of 100000h
● 100 lumens max output
● 40m max beam distance
● Powered by 1* AAA battery
● Intelligent hybric circuit
● 99% high transparent rate lens
● Precise vacuum plating reflector
● IP68 Water proof( 2m beneath water for 1 hour )
● 3 output levels
Wuben E01 is the first mini flashlight powered by 1* AAA battery among all Wuben flashlight, total length of 82.5mm, weights 29g with the included battery. Simple design and easy operation makes E01 a perfect EDC flashlight, you can check and purchase it at GearVita.com if you are interested in it: https://gearvita.com/wuben-e01-mini-portable-led-flashlight-100-lumens.html
Related products:
https://gearvita.com/fenix-ld02-mini-led-flashlight-100-lumens.html
https://gearvita.com/xiaomi-minimalist-portable-flashlight.html
High: 100lm ( 1h )
Med: 20lm ( 5h )
Low: 1lm ( 20h )
SOS: 20lm
Product Features:
● 3 output levels
Related products:
