- Feb 27, 1999
I thought you guys might be interested in this knife. Go to the fixed knife section and scroll to the bottom. You'll see what I mean.
www.simonichknives.com/idxtest.htm
Mike
I'm not sure if Mr. Simonich is using "pins" as such on this knife.
(BTW, Rob is one of today's great makers in my opinion.) If you go to
his site and examine the picture of the Kukhri, the picture is not clear
on this (even when enlarged). The knife pictured next to it in the SRT
series clearly shows, however, what look like socket head (or torqs
head) cap screws (tightened with an allen or torqs wrench) when
enlarged. This is also pretty common on many tactical knives,
particularly production pieces.
I can do this if you wish on all of the knives past the prototype (or I
can re-do the handles on the prototype). It will require the purchase of
a step drill(s), cap screws, and knurled nuts from one of the knife
maker's supply houses. I don't want to be tapping threads into hardened
steel (even relatively soft stuff), you'll go broke supplying me with
taps. Another option which might give a similar effect (although I've
never seen it done) would be to use commercially available (so I don't
have to do any lathe work), hardened steel dowel pins. The problem with
this approach is that any epoxy that leaks out past the pin will be very
hard to clean up in the holes (messy, messy, messy). Also, unless I can
find some stainless pins in the right sizes, they'll rust eventually.
The socket head cap screws are a better idea. BTW, the handles will
still have to be epoxied, otherwise the tangs will rust because of the
trapped water under the scales.
What I had originally planned (based on our earlier discussions) was two
brass pins coming all the way through and shaped to the outside contours
of the handle. The prototype is presently set up this way. Rob has some
similar handles on the page I mentioned. But, as long as you pick up the
cost of the screws, nuts & drills, I'm just as happy using the screws.
They can be installed using "won't come loose until the second coming"
Locktite and they'll be just as strong. We'll need to decide on two
large ones or several small ones.
I'll try to find a local supplier for the screws (the knurled nuts are
usually the problem). If I can't find anything local, I'll try
Halpernand others. I'll advise you as soon as I know the cost.
Work can go on with removing the ferrules, but I won't make any more
handles until we decide on the above.
This is not a problem. I
always consider the design "fluid" until the prototype is accepted. It
goes without saying, however, that the delivery window expands, so we
should freeze the design at that point.
Yours in hacking and slashing,
Robert Couture
New Highlander Engineering
couture@nhigheng.com http://www.nhigheng.com
Robert Couture
