LightningG
- Nov 19, 2014
I have a Microtech SoCom Elite, manual action (born 04/2019). I purchased it new from Knife Center in May. OD green with the Apocalyptic blade finish. Oh yeah!
When I first got it, I was impressed. I played with it a little bit and then put it in the knife case. I later sent it out to Rob (the ApostleP) for one of his sharpening jobs. Once I got it back, I oohed and ahhed over the amazing edge Rob put on there. Then back in the case. In both instances, I was so enamored with the thing, I didn't do my normal OCD check of the knife.
In September, I decided to put it in the rotation. For some reason, I did a blade play check. I was a little upset to discover it had lock rock. I could not only feel the movement, but could see it too. Ok, no problem, it's got a warranty. So off it went to get fixed. Fast forward 5 weeks...
Got it back from Microtech. The invoice said the lockbar was replaced. When I first pulled it out of the box, I noticed the detent was SUPER light, almost nonexistent. Hmm. The lock rock seemed lessened, but still there. I did a "gravity check." I held the knife perpendicular to the ground, blade side down, and moved my hand in a downward motion, and stopped that motion. The blade deployed! WTF?!?! I tried it a few more times with the same result. I've never had a knife do this...ever! Not even my cheap pocket knives. Ok, try to be positive...no problem, it's got a warranty, right? So off it went to get fixed, again. Fast forward to today...
Got it back from Microtech again. This time the invoice said, "lock surfaces polished and pivot adjusted. Strengthened detent." Um...right. It was pretty much the exact same way it was when I sent it in. And now, the blade is off center by about 1mm and there is a little side to side play. Are you kidding me?!?!
Called Microtech and went through the process again. This time, I was told that when it came in, it would be sent to their custom shop for repair. According to them, the custom shop takes care of the problem knife repairs.
So now that I've had the time to cool off and digest the situation, I've decided that no matter what happens (repair or replacement), the positive feelings I had towards the SoCom are now completely gone. And more than likely, the SoCom will be off to a new home.
Most are fixed, but not much drama to talk about with that. But not fixed draws alot of emotions out. So were more likely to hear about it.Your first issue was sending it to ApostleP.
But for real, sounds like a microtech issue. I've never understood why it's so common for these companies to get knives in and do absolutely nothing, while claiming they fixed it. See those types of stories all of the time about bigger companies. Its gotta be more of a waste of payroll to pretend to fix the knife multiple times than it is to actually fix it the first time.
Hope it works out for you though.
Not referring to you in particular but search the site and you will see this thread every few months. They have gotten much better with the customer service but no company is perfect, I used to think Kershaw/ZT was close but they seem to be slipping lately.How many times are we going to see what post? And I know you are not referring to me as "the same guys have issues with each maker" since I've only posted that I have 1 issue with 1 knife. Besides, it's a forum. Aren't we supposed to tell of our experiences and ask advice here?
