Xiaomi PLM11ZM wireless power bank is a new Xiaomi mobile power bank supporting wireless charging, which offers a capacity of 10000mAh. Except wired charging, it also has a wireless charging panel. You just need to put your smartphone on it and press the button, then the wireless charge will begin. Besides, the Xiaomi wireless power bank also offers 2 charging interface - USB-A and USB-C. Together with the wireless charging function, the power bank can charge 3 devices at the same time. In addition, it is certified by Qi wireless standard, so it can be intelligently compatible with different mobile phones.
The vertical induction distance of the wireless power bank is 5mm, so the smartphones with phone case (non-metallic material) also can be charged with the wireless charging function. Under the wireless charging mode, it can support up to 10W fast charging, and it will take 2 hours for Xiaomi Mi 9 to be fully charged.
Product Features:
● Equipped with wireless charging and two charging interfaces, USB-A and USB-C, to charge three devices simultaneously, one wireless and two wired.
● Support 10W wireless fast charging, and maximum power of 18W for fast charging, the time spent on it can be greatly shortened.
● Large sensing range, put it lightly, the phone can be charged by tapping the button.
● The vertical sensing distance is 5mm, and it can be charged with the phone case.
● The power required by the built-in chip to intelligently identify the device at the time of output can be supported by PD/QC3.0.
● QC2.0/BC1.2/iOS and other protocols for charging mobile phones, tablets and other devices.
● Comply with the wireless charging standard introduced by the Wireless Charging Alliance, compatible with Qi wireless charging smart devices, more devices are available.
● Uses high-quality lithium-ion polymer batteries, provide long-lasting battery life for smart devices.
● Intelligent FOD metal foreign object detection and protection avoid the situation that the power consumption is high due to the wrong placement of metal foreign objects such as keys and coins, eliminating the safety hazard.
● Can be carried around you, allowing you to charge wirelessly anytime, anywhere.
● One-piece metal case, high strength, resistant to falling and collision. The arc design allows for a single hand grip for a more comfortable grip. The non-slip soft elastic paint used in the charging panel has a good touch when it is non-slip.
Enjoy wireless charging anytime, anywhere, even on the plane, only a Xiaomi PLM11ZM needed, no connection, can also be charged with shell: https://gearvita.com/xiaomi-wireless-charger-power-bank-10000mah.html
You may also like:
huawei cp60 wireless charger
honor band 4 running
Product Features:
You may also like:
