The Xiaomi WiFi Amplifier Pro perfectly solves the problem about signal-loss and weak area connection, built-in 2 × 2dBi antenna with 300Mbps transmission speed, can penetrate walls or across multi floor house, boost an existing wireless network throughout all your home, and say goodbye to WiFi dead zones. Every family member will get to enjoy its benefits since the amplifier supports up to 64 devices connected at the same time.
Product Features:
● Two powerful high-gain external antennas expands WiFi signal range, ensures better wireless performance and stability.
● Wireless function makes your home wireless coverage larger, completely covers network dead zones with stronger signal.
● Compatible with other brands router, and transmission rate up to 2.4GHz and 300Mbps.
● Support up to 64 devices to fulfill the needs of the whole family, can be connected with various smart devices.
● Manage network settings easily with the Xiaomi Mi WiFi APP.
● Automatically upgrade the firmware while not working without any setting.
● Wall plug design, easy to save space and install or remove due to the compact size.
Home load bearing walls, doors and windows will make your router signal weaker, now you have simple solution to extend your signal further into your house. Cooperate with your router, the WiFi amplifier can extend WiFi signal and make it cover every corner of your home: https://gearvita.com/xiaomi-pro-300m-2-4ghz-wifi-amplifier-with-2-antenna.html
Recent hot selling products:
xiaomi redmi airdots
xiaomi 70mai pro
Product Features:
xiaomi 70mai pro
