Xiaomi 70mai car tire pressure monitor system has the dual USB which allows you to use the best way you want to use. It has the best usage and comes with the great battery power of 500mAh, can be recharged from the solar sun energy. Embraces auto check level sensor to help savvy wake-up, smart interconnection, ongoing observing, double charging and different capacities. The beneficiary receives two-shading negative show innovation to help constant observing weight and temperature of 4 tires. It has the Bolster 1 second to screen quick air release, exact to 0.1Bar. The Bolster battery high-temperature security, when high temperature up to 60 Deg.C, battery quits charging, likewise underpins astute wake-up. When the auto begins, the recipient in the rest sensor naturally awakens, consequently rest when ceased.
Product Features:
● Solar power and USB dual charging mode, convenient and environmentally friendly.
● Adopts car gauge level sensor to support intelligent wake-up, intelligent interconnection, real-time monitoring, dual charging and other functions.
● The receiver adopts two-color negative display technology to withstand the pressure and temperature real-time monitoring of 4 tires.
● Support 1 second to monitor rapid air leak, accurate to 0.1Bar.
● Support battery high-temperature protection, when high temperature up to 60 Deg.C, battery stops charging, also supports intelligent wake-up, when the car starts, the receiver on the sleep sensor automatically wakes up, automatically sleep when stopped.
● Intelligent connection of smart rearview mirror and mobile APP "70mai", wireless matching, easy to set up.
● Multi-model adaptation, supports customers to manually adjust the alarm range according to their own models, a variety of vehicle parameters recommended, one-button settings.
Anyone can use the 70mai tire pressure monitor in a modern way. Xiaomi smart control system will not only show when it's time to pump the wheels but will also measure the temperature in real time, as well as determine the puncture, allowing you to fix it before you feel it when it is too late. Deploy and configure the kit is quite simple, and all the necessary information will be in front of your eyes: https://gearvita.com/xiaomi-70mai-d...pressure-monitor-system-with-app-control.html
You may also like:
lenovo k5 pro 64gb
lenovo air tws bluetooth earphones
Product Features:
You may also like:
lenovo k5 pro 64gb
