With the Xiaomi Mijia 1080P IP camera, you can sleep soundly! The built-in 8pcs 940nm IR-cut LEDs and quiet motor enable this surveillance camera capture clear night vision images up to 9 meters distance silently. Besides, the rotatable design of the IP camera makes it capable of monitoring wider range in the horizontal and vertical direction via the APP control. What is more, the concealed TF card slot provides not only a beautiful and integrated appearance but also a convenient storage method for you.
Product Features:
● With the holder and accessories, the IP camera can be installed anywhere in many ways.
● Floating window of the APP for watching.
● Built-in 10pcs 940nm infrared cutting LED and quiet motor, enable it to capture the clear night vision image at a distance of up to 9 meters.
● Pan/tilt control with dual motors, 360 degree panorama viewing angle, maximumly reducing the blind spot.
● The rotary design enables it to monitor a larger range in horizontal and vertical direction through APP control.
● Hidden TF slot not only provides you with a beautiful and integrated appearance, but also provides you with a convenient way to store.
● You can set the detect time and direction, if any abnormality occurs, the IP camera will record 10s videos and send alarm to your phone.
● 1080P resolution, shoot high-quality and smooth video.
● Two-way audio, with internal microphone and speaker.
● Separate antenna, strong wireless signal to shooting smooth video.
● Support Android 4.0 and above, iOS 7.0 and above.
● "Mi Home" APP, download from Google Play or Apple Store.
Connection is also very simple, only three steps needed. First, download the "Mi Home" APP. Second, power the IP camera. Third, open the APP and connect the device. Then, you can use it. GearVita provides this powerful Xiaomi Mijia IP camera with the price of $34.99, you can go to buy: https://gearvita.com/xiaomi-mijia-1080p-ip-camera.html
Hot sale products:
cheap oneplus 6T 4g smartphone 256gb
cheap xiaomi mi max 3 4g smartphone
Product Features:
Hot sale products:
