The Xiaomi XGIMI Z6 projector adopts the DLP optical projection technology to project a 180-inch screen and achieve a high fidelity image and a clear bright vivid picture over a 200 - 300cm distance. The Z6 has an LED light (700 ANSI lumens 3D beamer) with 1920 × 1080 native resolution, which means that this projector is compatible with the 4K display. It also supports 2K and 1080P display thus you are at liberty to choose which display best fits the purpose.
Product Features:
● Native resolution is 1920 × 1080, can project in true HD and 2.25x clearer than mainstream 720P projectors (2073, 600 pixels).
● Motion compensation technology, through a specific algorithm to solve the image flutter and tailing problems when it is projecting high dynamic images, significantly increases the clarity and fidelity of dynamic pictures.
● Extensive keystone correction software, provides an optimal image from virtually any angle, eliminates many of the hassles of optimal set-up.
● 700 ANSI lumens, four channels optical path design, provides the incredible image color and viewing experience.
● Built in with fast auto focus function and professional high-definition camera, the image will be autofocused once the projector is on instead of manual operation.
● Supports HDR 10 decode, solves the low-contrast problem, presents a wider color range and more details in bright and dark areas.
● DRI technology provides extra eye protection from avoiding direct light to eyes.
● Active shutter 3D vision technology, perfectly turns 2D file sources to 3D.
● 1.2:1 projection ratio, projects an even bigger screen from the same distance.
● Top of the line harman/kardon customized stereo, provides superior theater-quality sound.
● Mstar 6A838 CPU and Mail-T820 GPU, supports videos with higher frame frequency, creates immersive audio-visual experience.
● 802.11ac WiFi technology, 2.4G/5G dual band WiFi, supports MIMO double transceiver function and provides more stable internet connection.
● HDMI (ARC) interface supports high quality image signal transmission.
● Optimized design, nest-shaped sound hole, silent heat dissipation, continuous surcature fillet, high transparency coated glass lens with overall protection.
● Support multi-language, such as Chinese Simplified, Chinese Traditional, English, German, Korean, French, Portuguese, Spanish, Malay, Indonesian, Russian, Arabic.
Z6 Polar can project a perfect square screen wherever you place it and it can seamlessly synchronize with images from your phone or computer via WiFi in seconds without using any cables which makes having fun easier and faster. Also, it can switch from standard version to business version so that working with software of file management on a large screen will show more details and complex things will look simple: https://gearvita.com/xiaomi-xgimi-z6-polar-projector.html
Xiaomi hot sale products:
xiaomi wowstick 1f+
xiaomi 70mai 1s dash cam
Product Features:
xiaomi wowstick 1f+
