AnotherDogDown17
- Jul 29, 2015
Oh my! Beautiful...
Sent from my SM-G920V using Tapatalk
I don't know how the OP did his but in my personal experience, using a q-tip that is wet with etchant to scrub off the blackened steel between applications gets me the deepest cut.How did you do the etch? The last stripper I did (oooo... that sounds kinda bad), I cleaned the logo with paint stripper (lost too much sleep, can't think of the chemical now!), then let pcb etchant sit on it for about 1.5 hours (full strength, replenishing about every half-hour). It barely etched it deeper, and now, after working so long to get the decarb off, it's almost gone.
That just looks soo much better than the black coating!
Did you do this by hand?
Not quite, but the dimples are very small and shallow with some light striations mixed in, so the sanding made it look almost smooth.Awesome!!! :thumbup:Looks like it was surface ground under the coating? Or are my eyes deceiving me?
Grinders scratch a little too deep and move too fast for my tastes so I don't mess with them. Lots of different abrasive materials, small hand tools & elbow grease applied in the right order as needed seem to work well. Years of trial and error can teach a guy some valuable experience too.Gorgeous, I was thinking about going for a double cut look. Did you use a grinder? Or stripper and sandpaper?
Sincerely,
Ego sum Chrysaora
Beautiful!
I'm guessing that you didn't take the scales off, and put in through a surface grinder. Which means that the flats of the blade just looked that good under the coating. Lucky you. :thumbup:
My strippers never look that good. :grumpy:![]()
Thanks everyone, I am very happy with how it turned out.
For the most part, but spine and talon holes well away from the edge get a little low speed powered attention to save time and achieve the desired result.
It isn't as smooth as it looks, or even BIG finish smooth, but it is pretty nice for that CF look.
Wash with dish soap & water, then something evaporative like alcohol or ether, then pool etchant on logo for as long as necessary to get the desired result. Some blades just don't want to etch as deep as others for reasons which are beyond me, but multiple applications eventually get the job done.
