munk said:That's disputable, Nasty.
You can keep them virginal if you like, but at least test them before storing them. And I'd add a few more users to your list. Using them really fulfulls the circle.
munk
Yvsa said:What Jeb is calling a "rabbit tang" is more properly known as a "partial tang." It isn't that any one tang has an advantage, or disadvantage, in strength one over another. Both the stick tang and full, or chiruwa, tang are equally strong and both equally prone to having water spilled on them if the kami isn't careful. The stick tang being thicker should hold up better if Jeb's theory was correct in the full tang being wider, what it makes up for in width it loses in thickness so if water is spilled it is going to harden that area and either are equally likely to fail if that happens.
The partial tang is just as strong as the other two. The problem doesn't lie with the tang, but the handle as it has more stress put on it because of its construction.
However if you drill and pin the handle and tang together, just takes one, it will hold until hell freezes over.
And you can beat it up just as hard as the other two tangs.
QUOTE]
Yvsa,
My concerns about the rabbit/partial are that it will put more pressure on the handle material and break it, or that it will simply pull right out, not being pinned.
A rabbit/partial that goes 3/4 of the way through the handle is of MUCH less concern to me than one that is less than or 1/2. And a pin will solve the pulling out problem. So a long, pinned rabbit tang is just as good or better than a full stick tang. Unfortunately, most khuks arent pinned, have shorter tangs, and are made with laha (which I find inferior to American epoxy)
When I talked about thickness, It was not between partials and full sticks, it was between both of those and a full (chiruwa) tang. Yes, water is just as likely to spill on any style, BUT, if it spills on a chiruwa, the whole thing wont be hardened. I guess what I am getting at here is a sort of differential hardening on the tang. Water on a thin tang can harden the whole thing before evaporating or heating up itself, while water on a thicker tang will only harden the front edge, leaving a still decent back, before it loses its cooling power or evaporates.
Whew! I hope that makes sense to everyone! It does in my twisted little mind.
Jebadiah_Smith said:Yvsa said:Both the stick tang and full, or chiruwa, tang are equally strong and both equally prone to having water spilled on them if the kami isn't careful. The stick tang being thicker should hold up better if Jeb's theory was correct in the full tang being wider, what it makes up for in width it loses in thickness so if water is spilled it is going to harden that area and either are equally likely to fail if that happens.I doubt it will pull out but you're right about the pressure and it possibly breaking.Jebadiah_Smith said:Yvsa,
The laha is good for about 5 years of hard everyday use in Nepal, but I agree that the modern epoxy is better, except when you want to remove and replace a handle.Jebadiah_Smith said:A rabbit/partial that goes 3/4 of the way through the handle is of MUCH less concern to me than one that is less than or 1/2. And a pin will solve the pulling out problem. So a long, pinned rabbit tang is just as good or better than a full stick tang. Unfortunately, most khuks arent pinned, have shorter tangs, and are made with laha (which I find inferior to American epoxy)
I knew that.Jebadiah_Smith said:When I talked about thickness, It was not between partials and full sticks,![]()
You're right, to a point. The fact is that the stick tang is less likely to be hardened all the way through due to its being thicker than the chiruwa tang. At the juncture where the water is liable to hit the stick tang is almost as wide as the chiruwa and is definitely stronger at that point.Jebadiah_Smith said:it was between both of those and a full (chiruwa) tang. Yes, water is just as likely to spill on any style, BUT, if it spills on a chiruwa, the whole thing wont be hardened.
Yup, and you've just stated the case why the stick tang is less likely to harden all the way through due to its being thicker, capish?Jebadiah_Smith said:I guess what I am getting at here is a sort of differential hardening on the tang. Water on a thin tang can harden the whole thing before evaporating or heating up itself, while water on a thicker tang will only harden the front edge, leaving a still decent back, before it loses its cooling power or evaporates.![]()
The argument is pretty moot in the fact that the tangs, all styles, are supposed to be dead soft. Any part of a tang that is even accidently hardened whether all the way through or not is more apt to breakage at some point in time.
The reason being that if any, even a small, portion of the tang is hardened and generates a crack then the crack is liable to eventually wander all the way through causing breakage.
It doesn't happen often but often enough to cause concern. A broken tang can/could cause great bodily harm. The kamis just need to be more careful.![]()
Yvsa said:Yup, and you've just stated the case why the stick tang is less likely to harden all the way through due to its being thicker, capish?![]()
Sorry you don't "capish," I'll see if I can 'splain it better.Jebadiah_Smith said:No, no capish. Every chiruwa ive seen is as thick as every stick tang of either variety that ive ever seen, it is also wider.
Jeb the rat tail and partial tangs are as thick as the blade and only a little narrower at the juncture of tang and blade. At the juncture where most of the rat tail tangs have failed the thickness would probably equal out to the width if it was forged thinner as the Chiruwa tangs are.Jebadiah_Smith said:I have no idea what you are talking about with the sticks being thicker and being able to resist full hardening.
The argument IS moot when it is between the rat tail and partial tangs versus the Chiruwa tang as the tangs are all equally strong.Jebadiah_Smith said:The argument is not moot because mistates ARE made, and some styles of tang are more resistant to critical failures than others.
I don't understand your reasoning behind this except that you could "possibly" see a crack forming that you couldn't see in a hidden tang?Jebadiah_Smith said:Its less likely that a chiruwa will break off without notice in mid swing and fly into your leg, either stick tang will.
It is a great discussion.Jebadiah_Smith said:Its more likely to break while prying. And sometimes, you can see the crack forming on a full tang. Dont get me wrong, when a stick is done right its better than a full tang, like Wayne Goddard says in his books, BUT, stick tangs arent always done right. Im not trying to be disrespectful, and I think this has been a great discussion.
Holding up Great!!!!Nasty said:How's the edge on that BDC holding up Edutsi? I have to admit that I sort of miss that one you old horse trader!![]()
Yup.Jebadiah_Smith said:I guess we are just going to have to agree to disagree here.
And therein lies the problem. If the kamis were more careful and didn't splash water on the stick tangs they would be done right and not fail.Jebadiah_Smith said:Dont get me wrong, when a stick is done right its better than a full tang, like Wayne Goddard says in his books, BUT, stick tangs arent always done right.
