scottNY said:email sent on the chitlangi.....
Roadrunner said:Anyone else notice the villager has a standard bolster? That makes me![]()
Aardvark said:Hey, Andersos, welcome.
Are you going to put a finish on the wood, or leave it raw? I agree with Nasty: very nice wood.
Originally Posted by ferguson
Norm,
I've used multiple coats of Birchwood-Casey Tru-Oil Gunstock finish on most of my handles. Tru-oil is available in many sporting goods sections where they sell the gun supplies. I got mine at Wal-Mart. According to the label it is a linseed oil based product. I'll bet the Watco finish can be used the same way. The process goes something like this.
1. Use mineral spirits and a toothbrush to remove the rouge if necessary,and wrap masking tape around the bolster to protect it from scratches.
2. Start sanding with 220 grit sandpaper. When down to bare wood, move to 320 grit, then 400, 600 grit, always sanding with the grain. I use a hacksaw blade with the "set" of the teeth ground off the sides to clean out the grooves.
3. Apply a heavy coat of Tru-Oil with your finger. You can even sand the wet Tru-Oil with 600 grit sandpaper to make a slurry of wood and finish to help fill the grain. Smooth it off with your finger.
4. After 2 days wipe off any that is still tacky, and let it dry 1 more day.
5. Lightly sand with 1000 grit wet or dry sandpaper. Wet the sandpaper in a bowl of water. It makes the finish very smooth, and keeps the paper from loading up. You don't want to remove finish, just dull it. You can reuse this piece of sandpaper til you complete one handle.
6. Dry off the handle thoroughly and recoat with a VERY THIN coat of Tru-Oil.
7. The following night, if the finish is dry, wet-sand, dry it off, and recoat with a THIN coat of Tru-Oil. Repeat every night until the pores are filled, and you can look deep into the finish and see the soul of the handle.
No stain is used.
Chandan and Rosewood are very oily woods. I have had problems with the Tru-Oil staying tacky for many days. If this happens, after each coat I heat the handle with a hair dryer for 2 or 3 minutes to set the finish. It seems to harden the finish before the woods natural oils can leach into it.
I'm not recommending these methods, just reporting what I've done. As always, your mileage may vary.
Thanks to Walosi and Yvsa for their input and past posts regarding refinishing handles!
Steve Ferguson
If you can post a picture on a webserver you can link to it and make it appear in your post by using the little icon that looks like a picture of mountains at the top of the posting screen. Several people here use free webservers and I'm sure someone will be around to give the link to one.WinterWolf said:I know I don't post too much but I would like to share pictures also. What level of membership do you need to be to post a few. Thanks in advance.
Yangdu said:Received some good news from DHL office.
Thank you for all your supports.
