Yellow Surefire G2X Pro flashlight for ??
jeepin
Feedback: +397 / =0 / -0
http://www.surefire.com/g2x-pro.html
I have an excellent condition Surefire G2X Pro flashlight for trade.
(GONE)
The G2X Pro is a compact yet powerful polymer-body flashlight that uses a high-efficiency LED—virtually immune to failure since there's no filament to burn out or break—to provide two light output levels: a brilliant, penetrating, perfectly pre-focused 320-lumen beam, and a 15-lumen low-output setting that lets you greatly extend the runtime per set of batteries, an invaluable option when you find yourself miles from civilization. Press the tailcap switch for momentary-on low, press further to click constant-on low, return to off and press or click on again within two seconds for high. The tough Nitrolon® polymer body is smoothly sculpted for a comfortable, secure grip and resists scratches, abrasion, and corrosion. A polycarbonate micro-textured reflector delivers a comparatively wider beam with generous peripheral light. We also make an aerospace aluminum-body version of this light, the 6PX Pro, and a single-output version with a tactical tailcap switch, the G2X Tactical.
Features
Virtually indestructible LED emitter regulated to maximize light output and runtime
Two output levels—high for maximum light, low for extended runtime
Precision micro-textured reflector creates smooth, optimized beam
Tough polycarbonate window resists impact
Tough Nitrolon® body, anodized aluminum bezel
Dual-output tailcap click switch—press for momentary-on low, click for constant-on low, return to off then press or click again for high
Weatherproof—O-ring and gasket sealed.
Treeshaker. I've tried to send 2 replies to your email but they've both come back as undeliverable.
