Yes, I admit it---I don't know how to drill a hole
t1mpani
Platinum Member
Well, specifically I don't know how to get through the ridiculously hard material I'm drilling.
I told my sister I'd re-handle a WÜSTHOF’s carving knife and fork set in mesquite for her husband. The factory handle scales came off in about thirty seconds. I'm now trying to drill the holes out to fit my corby rivets, and I have inadvertently discovered a new material----indestructanium. My cobalt and titanium coated bits won't TOUCH it! They made a nice little bevel around the edge of the hole, and then that's it. I'm quenching about every five seconds to keep the heat down, using the slowest rpm setup on my drill press, and am using a cutting oil. And yes, I started with smaller bits to work my way up in the hole, but after the first two size increases I can't go anywhere. Absolutely no exaggeration--I've been working on one side of the hole for the past forty-five minutes, and my caliper tells me I've descended just under 1/100".
Now, I'm guessing that because their tangs are so thin, they leave them fully hard so they won't bend and only temper their blades, but still!!? This is going to be something like 440A. Even at max hardness, my M2 drill bits covered with 70 HRC + coatings (and yes, I'm using new bits) should just eat it for breakfast.
Admittedly, this is mostly a rant but for heaven's sake if anybody can give me a helpful hint (I've reached the point where farm animal sacrifices will be readily considered) I'm all ears.
carbide is the only way you will get through hard steel. if you have a dremel tool you can get 1/8" shank diamond burrs that will work too.
Solid Carbide bits....Daggone expensive but dagdone worth it....plenty of lube also.
Solid carbide is in the 90-94 Rc range.....the steel you ar tryin to drill is probably 58-64 Rc..
The carbide will break/shatter pretty easily so be careful......
Good luck!
Or a tapered carbide bur, it will file its way thru and fairly fast/ They work great to enlarge holes in hardened material. Not going to get yo a precision hole but, they ate handy for a lot of things. I like the tree radius end or a taper radius. Not recommending the site below just good pictures
http://www.carbidebur.com/18shank/51series.htm
Carbide burrs, or mounted stones in your Dremel will work too.
Edit: I see a few of us were typing at the same time....
My thanks to you all----I have some carbide dremel bits, may be time to haul 'em out.
I appreciate it :thumbup::thumbup:
Carbide drills or burr's and don't forget to clamp the blade down when drilling, because the metal is hard the drills tend to grab just as it goes through.
Richard
I get my carbide burrs from www.northcoastknives.com. Suckers are cheap compared to what you pay for the carbide tile bits at Home depot and they work pretty good. I usually buy 5 or more at a time to make up for shipping cost. I never buy just that though. Curse of the knifemaker being I will also see at least 5 other things that I just have to have.:o Dan
Tried it before heading to work this morning and damned if that didn't work like a charm. Just hogged out close to the edges of the bevel the 7/32" bit had made on the rim of the hole with a 1/8" carbide rotary bit, and when it looked like there was almost no bevel left I went back to the drill and it clawed its way through in about ten seconds. The hole actually ended up perfectly round up front. I'll do the other one tonight, but it was very nice to leave home with a less defeated feeling that I'd had last night. :D
My thanks to all of you again--I love this forum. :cool:
I just got in a solid carbide spade bit for this kind of thing. I'll give it a spin (ho ho) later and see how it does...
good luck... only carbide will touch it. the steel is probably X50CrMoV15 Stainless Steel a high carbon chrome moly, it's an awesome steel for kitchens... it's got attitude too, kinda like if D2 and 4140 had a kid... Spade bits are ok in a pinch, watch out though most of the body's are made from aluminum or worse Copper and painted to look like steel! Try Enco or Fastenal to get real carbide jobber drill bits, but hold on to your wallet!
Jason
