You don't need to spend a fortune on a survival knife
I have three.
One user,
one loner ( very badly abused, when I picked it up on fleabay non original sheath for $AUD30 for those I wouldn't trust with my "good" knife)
And a mint Camillus that was sitting in the cabinet at work when I heard Camillus had gone under ( might be worth something in three or four hundred years)
I dulled the top of the point "clip" but left it angled so I could use it to scrape flint.
I replaced the issue stone with a diamond stone ( Smiths I think, can't break that by dropping it) and tied a paracord lanyard in the back groove in the handle.
That primary bevel leaves a lot to be desired I would hate to be sharpening that with the issued stone, for the first time in a ditch with bad guys chasing me .
So I put the user ( the loner wasn't too bad) on the magic Buck 136 honemaster ( why oh why did Buck stop making those??? They do turn up on Fleabay I would pay $Aud35-40 for one)
It now has a quiet respectable edge ( certainly cuts better than the one in the vid)
Carl
Carl
Yeah, the edge needs work in my opinion. Keep in mind, it was designed for bashing your way out of a cockpit, not for skinning or bushcraft. But still, you can re-bevel it, keep 90%+ of its strength and have a nice cutter. My biggest beef is the heat-treat, because everything else I can easily modify. The ones I've had are too darn soft... I suppose this is to make them easier to sharpen with the supplied stone... but I get pissy when I have to touch up a knife a couple times a day. The Ontario I beat on most... I can stick the tip in a 2x4 and bend it back and forth easily. :rolleyes: I once had one that simply snapped a 1/4" off the tip when I tried that... I don't recall which factory made it.
RE: Camillus... yeah I picked one up too when I found the factory was shutting down... as you said, it may be worth something in a couple centuries. ;)
