- Dec 2, 2005
Fair enough.
But the 2018 Forum knife won't qualify for the 2019 Knife of The Year, since I received it in 2018?
So I don't get in trouble, I'll go back to the Lil'Jack as my choice.
(P.S. "Had less than 3 hours" would be more accurate. )
I'm afraid not, though you could have asked @skblades to sit on it for a few weeks It's also worth noting that this thread is open until the 1st Jan 2019
I love how Jack poses the question (and I've taken the liberty of editing it a bit for emphasis and applicability to my KotY nomination):
This year I'm just going to cut to the chase and announce that my Knife of the Year is the Mora 120:
I actually purchased two of them this year. I bought my first in February, with the intention of grinding off the tip and using it for final cleanup carving on the rims of spoons. I suppose you could say it was going to be the slöjd knife equivalent of a spey blade. But, that never happened.
I already had a Mora 106 that I'd used quite a bit in spoon carving, so I was prepared for, and expecting, a very sharp, very useful laminated steel blade paired up with a comfortable handle. What I was not expecting, though, was how well it would fit into my whittling toolkit.
You see, I decided that I'd use it as the good folks at Morakniv intended before making any modifications. I used it a bit on a spoon and it was fine. But, then I started work on a larger-than-normal-for-me whittling project and decided to use it to help clear out some of the bulk before switching to my usual whittling knifes. Wow. The 120 is exceptional at clearing away the bulk and I find it to be more natural to use for that than the longer 106. It earned a permanent spot in my whittling tool roster that day.
Pretty soon bulk removal gave way to bulk removal and rough shaping. Then I was pushing that rough shaping to a bit more refinement before handing over to smaller, thinner blades. I even carved a few small projects exclusively with the 120, both to push my skills and to get an idea of what it can do. Suffice it to say that this is an extremely capable little knife. I'm sure with more practice I can get even more out of it.
You may notice the black Sharpie marks on the handle in the photo above. Those are indexing marks for consistent placement in the Tormek small knife jig. That's because this is also the knife that I used as a test bed for gaining experience with the "flat over hollow" grind that I talked about in a previous thread. It was the second Mora 120 that I purchased and is shown in both of these pictures.
I've learned a lot while using this knife and it has changed the way I approach many of my whittling projects. It's a delight to use and an exceptional value. For all of these reasons, this Mora 120 is my Knife of the Year.
Absolutely fascinating Greg
