smcfalls13 said:They'll be sharper than most knives(lower angle of the edge bevel) but they push what you're cutting to the side.
Wish I had a better way to explain it though....
Not sure a chisel grind is suitable for chopping, the edge would be too thin. I could be wrong though.![]()
SIFU1A said:works great for SD though.
smcfalls13 said:Not sure a chisel grind is suitable for chopping, the edge would be too thin.
Martinsite said:The vast majority of my chisel grinds are for tactical knives, where the top priority is getting the deepest cut and penetration with the least effort. For this application, the "zero thickness" chisel grinds excell, provided they are done PROPERLY.
A 1/4" thick chisel ground blade opens a wound that you can park a truck in!
kozak6 said:I don't like chisel grinds either.
If you put the edge of your knife on top of something (like a piece of fine cheese, for example), and push straight down, your knife will end up cutting at an angle.
It's really a pain if you are doing delicate cutting.
Knife Outlet said:The single bevel knife style comes from Japan where it is made in right or left handed versions ...
Most American knife makers, in their ignorance, tend to put a left handed grind on the blades so that the convex side will be on the mark side because it looks right that way.
