Zack Wood Prybar Clip-It Titanium
Feedback: +24 / =0 / -2
Zack Wood Clip-It
Great condition, used a to open a few new paint cans, worked great! Come with original packaging and makers card.
Item#ZW-PB-T-V2.2
$225 Net shipped
Ti2 Para-Biner PB-7
$50 shipped
A titanium carabiner for paracord and multi-tool for everyday carry.
Grade 5 Titanium (6Al4V) constructed body. The para-biner's shape is water-jetted using a high quality setting out of 5/16" thick sheets of grade 5 titanium. Then it is CNC milled, chamfered and drilled. Once the machining process is finished, the para-biner is tumbled in a proprietary stonewash leaving a uniform matte grey finish.
PB-7 measures 1.625" x 3.625" (41mm x 92mm); Weight 53 grams.
1/4” Hex Bit Driver
Drive anything that can be driven with a hex bit with the the innovative Ti2 Para-Biner gate latch. It holds hex bits with the superior tension provided by its spring-loaded G5 titanium billet gate.
Hex Wrenches in SAE and Metric.
SAE Versions
The Ti2 Para-Biner PB-7 SAE offers 7 wrench openings. Wrench Openings 15/16", 9/16", 1/2", 7/16", 3/8", 5/16", 1/4" (bit driver).
Metric Versions
The Ti2 Para-Biner PB-7 offer 7 wrench openings. Wrench Openings 24mm, 14mm, 13mm, 12mm, 10mm, 8mm, 1/4" (bit driver)
Screw Driver / Pry Bar / Box Opener
Use to drive flat head screws, pry a staple out, or sever the tape on your latest inbound shipment.
Para-System
The use of pulleys integrated with Ti2 Para-Biners minimizes friction and maximizes mechanical advantage when used singularly or in combinations to set up paracord-based rigging / hauling systems. This can help you at home in your garage as well as in the great outdoors.
Para-Pulley
Haul weighted objects up or down or keep them suspended with one or more Ti2 Para-Biners in various configurations such as “Block and Tackle.”
Para-Pulley -- A first in market integrated carabiner pulley system specifically designed to be used with paracord. Use the Para-Pulley singularly for directional change and greatly reduce friction. Or, use 2+ Ti2 Para-Biners and create a "block and tackle" scenario for a 2 to 1 mechanical advantage.
Para-Cinch
Temporarily tie off Ti2 Para-Biner paracord rigging setups that make use of Para-Pulleys, or use to quickly lash gear to fixed reference points.
Para-Cleat
More permanently tie off Ti2 Para-Biner paracord rigging setups and bolster gate closure by using a cleat that’s integral to the lower portion of the Ti2 Para-Biner billet gate.
Para-Wrap
Wrap paracord around the four corners of Ti2 Para-Biners to keep things neat and ready to deploy, especially for purpose-specific paracord setups that are pre-configured (already tied to Para-Biners) for rapid utilization.
Open bottles
What multi-tool would be complete without the ability to open a bottle of your favorite beverage!
Michael Zieba – Custom Cast Bronze Bead Brand New
$40 shipped
This piece is part of a Set of 3 – Speak no Evil, Hear no Evil, See no Evil
This is a very Unique ~ Hand Cast 3D Skull Bead ~ Hand Crafted in Bronze using the Lost Wax Method that provides exquisite detail to every aspect.
” Speak No Evil ”
The Bronze has amazing detail and very unique coloring ~ rotated in natural Light you can easily see the Heat Coloring change!
This Size was made for a Knife Lanyard accessory or easy KeyChain carry.
