Since I'm assuming you're not actually making a knife with the steel...they're both high wear resistance PM steels that are close enough that you should choose between the two based on which knife you'd rather buy.
Lets complicate this - does anyone have experience with CPM 110V? I see Kershaw will be using it on a sprint-run Shallot.
ZDP189 much much better then SG2. SG2 is around AUS8 and actually Sandvic 13C26 shows better result then SG2 even CRKT MI AUS8 shows better results on my tests. I tested both JYDII and JYD2 Ti/SG2, with 3 time cheaper regular JYDII did better job:
http://playground.sun.com/~vasya/Manila-Rope-Results.html
Thanks, Vassili.
Ok thanks guys I will end up with a stretch 2 or JYG sg2 by the end of this weekend.![]()
I have both now.![]()
I see no difference in whittling hair with ZDP189 as well as with SG2 or any other steel.
Thanks, Vassili.
