Zebralight SC600W II L2 (SOLD)
Feedback: +16 / =0 / -0
I have two Zebralight flashlights for sale today. The SC52 is sold, SC600II L2 is stlil available. They do not include any batteries. The prices are via Paypal goods and include shipping to the continental United States only. First post with "I'll take it" followed by prompt payment gets the requested item.
1)Zebralight SC600W II L2- SOLD
This model has the following specifications:
LED: Cree XM-L2 Neutral White (Nominal CCT 4400K)
User Selectable Levels: 3 main levels (High, Medium and Low). Each main level can be programmed to one of its two sub-levels. The second sub-level of the each main levels can be further programmed to different brightness levels.
Light Output (runtimes)
High: H1 1020 Lm (PID, approx 2 hr) or H2 620 Lm (PID, approx 2.5 hrs) / 330 Lm (3.9 hrs) / 150 Lm (11 hrs)
Medium: M1 65 Lm (30 hrs) or M2 30 Lm (66 hrs) / 11 Lm (172 hrs)
Low: L1 3.5 Lm (16 days) or L2 0.4 Lm (2.5 months) / 0.06 Lm (4.6 months) / 0.01 Lm (5.5 months)
Beacon Strobe Mode: 0.2Hz Beacon at Low / 0.2Hz Beacon at H1 / 4Hz Strobe at H1 / 19Hz Strobe at H1
Operating Voltage Range: 2.7V - 4.2V
Battery: One protected or unprotected 18650 size (up to 69mm long) 3.6/3.7V li-ion rechargeable.
Parasitic Drain: Negligible (much less than the self discharging of a battery)
Dimensions
Head Diameter: 30 mm
Body Diameter: 25 mm
Length: 101.6 mm
Weight
2.75 oz (78 gram) without battery
2) Zebralight SC52 CW- SOLD
LED: Cree XM-L Cool White (Nominal CCT 6300K)
User Selectable Levels: 3 main levels (High, Medium and Low). Each main level can be programmed to one of its two sub-levels. The second sub-level of the each main levels can be further programmed to different brightness levels or strobes.
Light Output:
High: H1 280 Lm (0.9 hrs) or H2 172 Lm (1.7 hrs) / 108 Lm (3 hrs) / 4Hz Strobe
Medium: M1 50 Lm (7.5 hrs) or M2 25 Lm (12 hrs) / 12 Lm (27 hrs)
Low: L1 2.7 Lm (4 days) or L2 0.34 Lm (3 weeks) / 0.06 Lm (2 months) / 0.01 Lm (3 months)
Light output are ANSI out the front values. Runtime tests are done using Sanyo 2000mAh Eneloop AA batteries. Light output with 14500 batteries are the same except that the H1 is 500Lm for the first minute and then steps down to 280Lm.
Operating Voltage Range: 0.7V - 4.2V
Battery: One 1.5V AA (NiMH, lithium or alkaline) or 3.7V 14500 Li-ion battery.
Dimensions: Diameter: 0.93 inch (23.6 mm), Length: 3.08 inch (78.2 mm)
Weight: 1.4 oz (40 gram)
