- Mar 8, 2008
I don't see a scandi grind as a zero grind, unless the grind goes all the way to the spine. It's more like a high chisel grind.
A zero grind should start at the spine and have no separate edge bevel.
"Scandi grind" is just a shorthand term for "zero saber flat grind" (although most scandis are actually very slightly hollow from the factory.) A zero grind is any grind in which the edge bevel is the only bevel, regardless of height or if it's convex, flat, or hollow. A microbevel is typically considered permissible within the definition, but a lot of people misunderstand just how slight a true microbevel is. They're made using only around 1-3 light strokes on a stone and shouldn't be visible without having to deliberately look for it. A zero grind in which it went all the way to the spine would be a "full zero grind".
